Datasheet SN54HC30, SN74HC30 (Texas Instruments)
ManufacturerTexas Instruments
Description8-Input Positive-NAND Gates
Pages / Page4 / 1 — REI Datasheet. SN54HC30, SN74HC30. Quality Overview. Rochester …
File Format / SizePDF / 461 Kb
REI Datasheet. SN54HC30, SN74HC30. Quality Overview. Rochester Electronics. Manufactured Components
Datasheet SN54HC30, SN74HC30 Texas Instruments
REI Datasheet SN54HC30, SN74HC30
8-Input Positive-NAND Gates These devices contain a single 8-input NAND gate and perform the following Boolean functions in positive logic: Y = A•B•C•D•E•F•G•H or Y = A+B+C+D+E+F+G+H The SN54HC30 is characterized for operation over the full military temperature range of -55°C to 125°C while the SN74HC30 is characterized for operation from -40°C to 85°C.
Quality Overview Rochester Electronics Manufactured Components
• ISO-9001 • AS9120 certification Rochester branded components are • Qualified Manufacturers List (QML) MIL-PRF-38535 manufactured using either die/wafers • Class Q Military purchased from the original suppliers • Class V Space Level or Rochester wafers recreated from the • Qualified Suppliers List of Distributors (QSLD) original IP. All recreations are done with • Rochester is a critical supplier to DLA and the approval of the OCM. meets all industry and DLA standards. Parts are tested using original factory Rochester Electronics, LLC is committed to supplying test programs or Rochester developed products that satisfy customer expectations for test solutions to guarantee product quality and are equal to those originally supplied by meets or exceeds the OCM data sheet. industry manufacturers. The original manufacturer’s datasheet accompanying this document reflects the performance and specifications of the Rochester manufactured version of this device. Rochester Electronics guarantees the performance of its semiconductor products to the original OEM specifications. ‘Typical’ values are for reference purposes only. Certain minimum or maximum ratings may be based on product characterization, design, simulation, or sample testing. © 2013 Rochester Electronics, LLC. All Rights Reserved 11142013 To learn more, please visit www.rocelec.com Document Outline RE_DScover_SN54_74HC30_14nov13 SN54_74HC30 (TIS)
