Datasheet AD626 (Analog Devices) - 7
DescriptionLow Cost, Single-Supply Differential Amplifier
Pages / Page14 / 7 — Typical Performance Characteristics–AD626. S =. GAIN = 10, 100. CM FOR …
RevisionD
File Format / SizePDF / 659 Kb
Typical Performance Characteristics–AD626. S =. GAIN = 10, 100. CM FOR SINGLE. AND DUAL SUPPLIES. VCM FOR DUAL
Typical Performance Characteristics–AD626 S = GAIN = 10, 100 CM FOR SINGLE AND DUAL SUPPLIES VCM FOR DUAL
Typical Performance Characteristics–AD626 25 6 V 5 S =
5V GAIN = 10, 100 20 4
V 15 CM FOR SINGLE AND DUAL SUPPLIES 3 2 10 1 5
VCM FOR DUAL INPUT COMMON-MODE RANGE – V POSITIVE OUTPUT VOLTAGE – V SUPPLIES ONLY 0 0 –1 1 2 3 4 5 10 100 10k 1k SUPPLY VOLTAGE –
V LOAD RESISTANCE –
⍀ TPC 1. Input Common-Mode Range vs. Supply TPC 4. Positive Output Voltage Swing vs. Resistive Load
5 –6 TA = 25
C –5 4 SINGLE AND –4 DUAL SUPPLY 3 –3 GAIN = 10 –2 2 GAIN = 100 DUAL SUPPLY –1 ONLY 1 NEGATIVE OUTPUT VOLTAGE – V 0 POSITIVE OUTPUT VOLTAGE SWING – V 0 1 0 1 2 3 4 5 100 1k 100k 10k SUPPLY VOLTAGE – V LOAD RESISTANCE –
⍀ TPC 2. Positive Output Voltage Swing vs. Supply Voltage TPC 5. Negative Output Voltage Swing vs. Resistive Load
–5 30 TA = 25
C V –4
20 –3 DUAL SUPPLY ONLY –2 10 –1 CHANGE IN OFFSET VOLTAGE – NEGATIVE OUTPUT VOLTAGE SWING – V 0 0 1 2 3 4 5 0 SUPPLY VOLTAGE – V 0 1 2 3 4 5 WARM-UP TIME – Minutes
TPC 3. Negative Output Voltage Swing vs. Supply Voltage TPC 6. Change in Input Offset Voltage vs. Warm-Up Time REV. D –5– Document Outline FEATURES APPLICATIONS PRODUCT DESCRIPTION CONECTION DIAGRAM SPECIFICATIONS SINGLE SUPPLY DUAL SUPPLY ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE Typical Performance Characteristics THEORY OF OPERATION ADJUSTING THE GAIN OF THE AD626 SINGLE-POLE LOW-PASS FILTERING CURRENT SENSOR INTERFACE BRIDGE APPLICATION OUTLINE DIMENSIONS Revision History
