24 /7 — AD8601/AD8602/AD8604. 300. VS = 3V. 250. ) A. A) p. ( 200. NT 20. RRE. …
Revision
G
PDF / 352 Kb
AD8601/AD8602/AD8604. 300. VS = 3V. 250. ) A. A) p. ( 200. NT 20. RRE. URRE. 150. C 15. T E. S F. 100. INP. –40. –25. –10. 110. 125. TEMPERATURE (°C). VS = 5V. 10k
AD8601/AD8602/AD860430030VS = 3VVS = 3V25025) AA) p(p( 200NT 20NTRREURRE150C 15CUT EASS FBIF100OUT10UTINPINP5050 1 0 4 –40–25–105203550658095110125 01 –40–25–105203550658095110125 01 5- 5- TEMPERATURE (°C) 52 TEMPERATURE (°C) 52 01 01 Figure 11. Input Bias Current vs. Temperature Figure 14. Input Offset Current vs. Temperature 30030VS = 5VVS = 5V25025) AA) p(p( 200NT 20NTRREURRE150C 15CUT EASS FBIF100OUT10UTINPINP5050 2 0 5 –40–25–105203550658095110125 01 –40–25–105203550658095110125 01 5- 5- TEMPERATURE (°C) 52 TEMPERATURE (°C) 52 01 01 Figure 12. Input Bias Current vs. Temperature Figure 15. Input Offset Current vs. Temperature 510kVVS = 5VS = 2.7VTTA = 25°CA = 25°C41kA) pV)((mNTE3REG 100A T LSOURCECURSINKVOAS2T10BIU P TUT PU OIN110 3 0.1 16 00.51.01.52.02.53.03.54.04.55.0 01 0 5- 0.0010.010.1110100 5- COMMON-MODE VOLTAGE (V) 52 52 01 LOAD CURRENT (mA) 01 Figure 13. Input Bias Current vs. Common-Mode Voltage Figure 16. Output Voltage to Supply Rail vs. Load Current Rev. G | Page 7 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION RAIL-TO-RAIL INPUT STAGE INPUT OVERVOLTAGE PROTECTION OVERDRIVE RECOVERY POWER-ON TIME USING THE AD8602 IN HIGH SOURCE IMPEDANCE APPLICATIONS HIGH SIDE AND LOW SIDE, PRECISION CURRENT MONITORING USING THE AD8601 IN SINGLE-SUPPLY, MIXED SIGNAL APPLICATIONS PC100 COMPLIANCE FOR COMPUTER AUDIO APPLICATIONS SPICE MODEL OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
