Datasheet AD8601, AD8602, AD8604 (Analog Devices) - 9
DescriptionPrecision CMOS, Single-Supply, Rail-to-Rail, Input/Output Wideband Operational Amplifiers
Pages / Page24 / 9 — AD8601/AD8602/AD8604. 120. –90. 3.0. VS = 5V. 100. RL = NO LOAD –45 TA = …
RevisionG
File Format / SizePDF / 352 Kb
AD8601/AD8602/AD8604. 120. –90. 3.0. VS = 5V. 100. RL = NO LOAD –45 TA = 25°C. 2.5. VS = 2.7V V. IN = 2.6V p-p. -p). RL = 2kΩ. rees). p 2.0
AD8601/AD8602/AD8604 120 –90 3.0 VS = 5V 100 RL = NO LOAD –45 TA = 25°C 2.5 VS = 2.7V V IN = 2.6V p-p -p) RL = 2kΩ rees) p 2.0
AD8601/AD8602/AD8604 120 –90 3.0 VS = 5V 100 RL = NO LOAD –45 TA = 25°C 2.5 80 0 VS = 2.7V V 60 45 IN = 2.6V p-p -p) RL = 2kΩ rees) p 2.0 V TA = 25°C ) 40 PHASE 90 eg B D G ( AV = 1 d ( ( IN 20 135 T 1.5 IN IF W H S GA T 0 180 S GAIN E U AS TP 1.0 –20 225 H P OU –40 270 0.5 –60 315 –80 360 0
23 26
1k 10k 100k 1M 10M 100M
0
1k 10k 100k 1M 10M
0 5- 5-
FREQUENCY (Hz)
52
FREQUENCY (Hz)
52 01 01 Figure 23. Open-Loop Gain and Phase vs. Frequency Figure 26. Closed-Loop Output Voltage Swing vs. Frequency
6 VS = 3V TA = 25°C AV = 100 40 5 B) VS = 5V d -p) V A IN = 4.9V p-p N ( V = 10 p 4 RL = 2kΩ 20 AI V TA = 25°C G G ( A P IN V = 1 O 3 O A W L V = 1 S 0 T D- S U O TP 2 CL OU 1
24
0 1k 10k 100k 1M 10M 100M
0 27 5-
1k 10k 100k 1M 10M
0 5-
FREQUENCY (Hz)
52 01
FREQUENCY (Hz)
52 01 Figure 24. Closed-Loop Gain vs. Frequency Figure 27. Closed-Loop Output Voltage Swing vs. Frequency
200 VS = 5V VS = 3V TA = 25°C 180 TA = 25°C AV = 100 40 160 B) ) d (Ω 140 A N ( V = 10 A 20 V = 100 AI 120 G P DANCE O E P 100 O A L V = 1 M A 0 I V = 10 D- 80 S UT O P CL UT 60 O AV = 1 40 20
25
0 28 5-
0 5-
FREQUENCY (Hz)
52 52 01
FREQUENCY (Hz)
01 Figure 25. Closed-Loop Gain vs. Frequency Figure 28. Output Impedance vs. Frequency Rev. G | Page 9 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION RAIL-TO-RAIL INPUT STAGE INPUT OVERVOLTAGE PROTECTION OVERDRIVE RECOVERY POWER-ON TIME USING THE AD8602 IN HIGH SOURCE IMPEDANCE APPLICATIONS HIGH SIDE AND LOW SIDE, PRECISION CURRENT MONITORING USING THE AD8601 IN SINGLE-SUPPLY, MIXED SIGNAL APPLICATIONS PC100 COMPLIANCE FOR COMPUTER AUDIO APPLICATIONS SPICE MODEL OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
