Datasheets - Differential Amplifiers Linear Technology - 5
Subsection: "Differential Amplifiers"
Manufacturer: "Linear Technology"
Search results: 99 Output: 81-99
View: List / Images
  1. Datasheet LTC6405CUD - Linear Technology DIFF AMP, 5 V, 2.7GHZ, R/R, 16QFN
    Part Number: LTC6405CUD Manufacturer: Linear Technology Description: DIFF AMP, 5 V, 2.7GHZ, R/R, 16QFN Download Data Sheet Specifications: Amplifier Case Style: QFN Bandwidth: 2.7GHz Base Number: 6405 Gain dB Max: 1 dB Input Offset Voltage Max: 7 ...
  2. Datasheet LTC6405CMS8E - Linear Technology IC, DIFF AMP< 2.7GHZ, 5 V, LN, 8MSOP
    Part Number: LTC6405CMS8E Manufacturer: Linear Technology Description: IC, DIFF AMP< 2.7GHZ, 5 V, LN, 8MSOP Download Data Sheet Specifications: Amplifier Case Style: MSOP Bandwidth: 2.7GHz Base Number: 6405 Gain dB Max: 1 dB Input Offset Voltage ...
  1. Datasheet LTC6401IUD-20 - Linear Technology IC, DIFF ADC, DRIVER 1.3  GHz, QFN-16
    Part Number: LTC6401IUD-20 Manufacturer: Linear Technology Description: IC, DIFF ADC, DRIVER 1.3 GHz, QFN-16 Download Data Sheet Specifications: Bandwidth: 1.3 GHz Base Number: 6401 Gain Max: 10 dB Input Offset Voltage Max: 2 mV Input Offset ...
  2. Datasheet LTC6400IUD-20 - Linear Technology IC, DIFF ADC, DRIVER 1.8GHZ, QFN-16
    Part Number: LTC6400IUD-20 Manufacturer: Linear Technology Description: IC, DIFF ADC, DRIVER 1.8GHZ, QFN-16 Download Data Sheet Specifications: Amplifier Case Style: QFN Bandwidth: 1.8GHz Base Number: 6400 Gain dB Max: 10 dB Input Offset Voltage ...
  3. Datasheet LTC1992HMS8 - Linear Technology IC, SM, OP AMP, DIFF
    Part Number: LTC1992HMS8 Manufacturer: Linear Technology Description: IC, SM, OP AMP, DIFF Download Data Sheet Docket: LTC1992 Family Low Power, Fully Differential Input/Output Amplifier/Driver Family FEATURES DESCRIPTIO Adjustable Gain and Fixed ...
  4. Datasheet LTC1992CMS8 - Linear Technology IC, SM, OP AMP, DIFF
    Part Number: LTC1992CMS8 Manufacturer: Linear Technology Description: IC, SM, OP AMP, DIFF Download Data Sheet Docket: LTC1992 Family Low Power, Fully Differential Input/Output Amplifier/Driver Family FEATURES DESCRIPTIO Adjustable Gain and Fixed ...
  5. Datasheet LTC1992-2HMS8 - Linear Technology IC, SM, OP AMP, DIFF
    Part Number: LTC1992-2HMS8 Manufacturer: Linear Technology Description: IC, SM, OP AMP, DIFF Download Data Sheet Docket: LTC1992 Family Low Power, Fully Differential Input/Output Amplifier/Driver Family FEATURES DESCRIPTIO Adjustable Gain and Fixed ...
  6. Datasheet LTC1992-1CMS8 - Linear Technology IC, SM, OP AMP, DIFF
    Part Number: LTC1992-1CMS8 Manufacturer: Linear Technology Description: IC, SM, OP AMP, DIFF Download Data Sheet Docket: LTC1992 Family Low Power, Fully Differential Input/Output Amplifier/Driver Family FEATURES DESCRIPTIO Adjustable Gain and Fixed ...
  7. Datasheet LT6600IS8-5 - Linear Technology AMP, DIFFERENTIAL, 5 MHz LPF, SO-8
    Part Number: LT6600IS8-5 Manufacturer: Linear Technology Description: AMP, DIFFERENTIAL, 5 MHz LPF, SO-8 Download Data Sheet Docket: LT6600-5 Very Low Noise, Differential Amplifier and 5MHz Lowpass Filter FEATURES DESCRIPTIO Programmable ...
  8. Datasheet LT6600IS8-20 - Linear Technology AMP, DIFFERENTIAL, 20 MHz LPF, SO-8
    Part Number: LT6600IS8-20 Manufacturer: Linear Technology Description: AMP, DIFFERENTIAL, 20 MHz LPF, SO-8 Download Data Sheet Docket: LT6600-20 Very Low Noise, Differential Amplifier and 20MHz Lowpass Filter FEATURES s s s s DESCRIPTIO s s ...
  9. Datasheet LT6600IS8-10 - Linear Technology AMP, DIFFERENTIAL, 10 MHz LPF, SO-8
    Part Number: LT6600IS8-10 Manufacturer: Linear Technology Description: AMP, DIFFERENTIAL, 10 MHz LPF, SO-8 Download Data Sheet Docket: LT6600-10 Very Low Noise, Differential Amplifier and 10MHz Lowpass Filter FEATURES s s s s DESCRIPTIO s s ...
  10. Datasheet LT6600CS8-2.5 - Linear Technology DIFF AMP, 2.5 MHz, LP FILTER, 8SOIC
    Part Number: LT6600CS8-2.5 Manufacturer: Linear Technology Description: DIFF AMP, 2.5 MHz, LP FILTER, 8SOIC Specifications: Amplifier Case Style: SOIC Amplifier Type: Low Noise Base Number: 6600 Input Offset Voltage: 35 mV Mounting Type: SMD Number ...
  11. Datasheet LT6402CUD-20 - Linear Technology IC, SM, OP AMP, DIFF
    Part Number: LT6402CUD-20 Manufacturer: Linear Technology Description: IC, SM, OP AMP, DIFF Download Data Sheet Docket: FEATURES LT6402-20 300MHz Low Distortion, Low Noise Differential Amplifier/ ADC Driver (AV = 20dB) DESCRIPTIO The LT®6402-20 is ...
  12. Datasheet LT1994IMS8 - Linear Technology AMP, DIFFERENTIAL, I/O, SMD, MSOP8
    Part Number: LT1994IMS8 Manufacturer: Linear Technology Description: AMP, DIFFERENTIAL, I/O, SMD, MSOP8 Download Data Sheet Docket: LT1994 Low Noise, Low Distortion Fully Differential Input/ Output Amplifier/Driver FEATURES DESCRIPTIO Fully ...
  13. Datasheet LT1994CMS8 - Linear Technology IC, SM, OP AMP, DIFF
    Part Number: LT1994CMS8 Manufacturer: Linear Technology Description: IC, SM, OP AMP, DIFF Download Data Sheet Docket: LT1994 Low Noise, Low Distortion Fully Differential Input/ Output Amplifier/Driver FEATURES DESCRIPTIO Fully Differential Input ...
  14. Datasheet LT1993IUD-2 - Linear Technology AMP, DIFFERENTIAL, DC-0.8GHZ, SMD
    Part Number: LT1993IUD-2 Manufacturer: Linear Technology Description: AMP, DIFFERENTIAL, DC-0.8GHZ, SMD Download Data Sheet Docket: FEATURES LT1993-2 800MHz Low Distortion, Low Noise Differential Amplifier/ ADC Driver (AV = 2V /V) DESCRIPTIO The ...
  15. Datasheet LT1993IUD-10 - Linear Technology AMP, DIFFERENTIAL, DC-0.7GHZ, SMD
    Part Number: LT1993IUD-10 Manufacturer: Linear Technology Description: AMP, DIFFERENTIAL, DC-0.7GHZ, SMD Download Data Sheet Docket: FEATURES LT1993-10 700MHz Low Distortion, Low Noise Differential Amplifier/ ADC Driver (AV = 10V/V) DESCRIPTIO The ...
  16. Datasheet LT1990CS8 - Linear Technology IC, SM, OP AMP, DIFF
    Part Number: LT1990CS8 Manufacturer: Linear Technology Description: IC, SM, OP AMP, DIFF Download Data Sheet Docket: LT1990 ±250V Input Range G = 1, 10, Micropower, Difference Amplifier DESCRIPTIO The LT®1990 is a micropower precision difference ...
  17. Datasheet LT1990ACS8 - Linear Technology IC, SM, OP AMP, DIFF
    Part Number: LT1990ACS8 Manufacturer: Linear Technology Description: IC, SM, OP AMP, DIFF Download Data Sheet Docket: LT1990 ±250V Input Range G = 1, 10, Micropower, Difference Amplifier DESCRIPTIO The LT®1990 is a micropower precision difference ...
Sort by: relevance / date
