Op-amps from Diodes Corp raise audio performance
Diodes APX4558
With a low input noise performance of only 8nV/√Hz at 1kHz, the APX4558 dual channel op-amps from Diodes Incorporated meet demands for higher performance audio without an increase in BOM cost.
This performance, coupled with a wide unity gain bandwidth of 3MHz, makes the op-amps well suited to a broad range of cost-sensitive audio products including set top boxes and pre-amplifiers.
Diodes - APX4558
Two variants are being offered by Diodes, the commercial grade APX4558 with an operating temperature range of 0ºC to 70ºC and the industrial grade APX4558I, operating from -40ºC up to 105ºC. Both new parts are provided in the SO8 package and are pin-for-pin compatible with industry standard op-amp alternatives.
The op-amps are short-circuit protected and the devices’ internal compensation delivers stability that removes the need for additional external frequency compensation components. The parts are priced at $0.08 each in 1k quantities.
