Versatile, universal non-contact Triaxis sensors promise simply limitless Linear, Rotary and 3D position sensing options in automotive, industrial, medical and consumer products
Melexis MLX90360 MLX90363
Melexis newest generation of Triaxis sensors bring second generation advancements to challenging applications in harsh environments. The Triaxis technology has proven to be a leading solution to a variety of position sensing requirements. EGR Valves, Turbo Wastegate Actuators, Electronic Throttle Body solutions, Steering angle, Suspension Height, Transmission Clutch; Shift and Fork position and Human Machine Interface are among the successful problems solved by Triaxis technology.
The MLX90360 and MLX90363 bring to market the next generation of Triaxis technology. Using lessons learned from over 6 years of applications support and design wins Melexis has engineered two advanced chips for all Linear, Rotary and 3D non-contact position sensing. Both devices are available in single and dual redundant implementations to cost-effectively address the full range of applications, including safety critical sensing requirements.
Melexis - MLX90360, MLX90363
The MLX90360 provides analog or PWM output with fully programmable capabilities to simplify application development. Linear or rotary position sensing with direct, point-to-point, connection to the control electronics and in circuit “programming through the connector” highlight the value of the MLX90360.
 Universal, maximum flexibility for applications development can be accomplished with the MLX90363. Designed to be paired with an off-the-shelf microcontroller, the MLX90363 relies on SPI output communication. The range of position sensing applications are limitless and constrained only by the imagination of the designer. 3D, rotary, linear or even mixed mode implementations can be accomplished through embedded software in the customer’s microcontroller. All internal raw and conditioned signals from the IMC (Integrated Magneto Concentrator) Triaxis sensor can be communicated over the SPI channel. This puts the BX, BY and BZ information directly accessible for processing by the embedded microcontroller. Data from the on chip temperature sensor and from the internal chip diagnostics can also be digitally transmitted. Programming happens through the same channel.
MLX90360 Block Diagram
Typical application of MLX90360 – Linear
MLX90363 Block Diagram
melexis.com
