International Rectifier announced the introduction of a family of reliable, efficient 1200 V Insulated Gate Bipolar Transistors (IGBTs) for induction heating, uninterruptible power supplies (UPS) solar and welding applications.
The new family of ultra-fast 1200 V IGBTs utilizes thin wafer Field-Stop Trench technology that significantly reduces switching and conduction losses to deliver higher power density and greater efficiency at higher frequencies. These devices are further optimized for applications that do not require short-circuit capability such as UPS, solar inverters, and welding, and complement IR’s products with 10 microsecond short circuit capability for motor drive applications.
Covering a broad current range from 20 – 50 A as packaged devices and up to 150A for die products, key performance benefits include wide square reverse bias safe operating area (RBSOA), positive VCE(on) temperature coefficient, and low VCE(on) to reduce power dissipation and achieve higher power density. In addition, devices are available with or without an internal ultra-fast soft recovery diode. Die products are also available with solderable front metal (SFM) for improved thermal performance, reliability and efficiency.
Specifications
Part Number
Package
I(nom)
Vceon
Rth(j-c)
TO247
20
1.9
0.70 ºC/W
TO247 - Copack
TO247
30
1.7
0.39 ºC/W
TO247 - Copack
TO247
40
1.7
0.32 ºC/W
TO247 - Copack
TO247
50
1.7
0.27 ºC/W
Sup.TO247 - Copack
Availability and Pricing
Pricing for the IRG7PH35UPBF begins at US $3.00 each in 10,000-unit quantities. Production quantities are available immediately. Prices are subject to change.
