New Vishay 600 V and 650 V N-Channel Power MOSFETs Feature Currents From 22 A to 47 A and Ultra-Low Maximum On-Resistance Down to 64 mΩ
Vishay SiHP22N60E SiHF22N60E SiHG22N60E SiHB22N60E SiHP24N65E SiHG24N65E SiHB24N65E SiHP30N60E SiHF30N60E SiHG30N60E SiHB30N60E SiHG47N60E
Vishay released a new series of 600 V and 650 V n-channel power MOSFETs with ultra-low maximum on resistance from 64 mΩ to 190 mΩ at 10 V, and a wide range of current ratings from 22 A to 47 A. Based on Vishay’s next generation of Super Junction Technology, the E Series MOSFETs offer ultra-low gate charge and low gate charge times on-resistance, a key figure of merit (FOM) for MOSFETs used in power conversion applications.
Vishay - SiHP22N60E, SiHF22N60E, SiHG22N60E, SiHB22N60E, SiHP24N65E, SiHG24N65E, SiHB24N65E, SiHP30N60E, SiHF30N60E, SiHG30N60E, SiHB30N60E, SiHG47N60E
With the new E Series technology, on-resistance is reduced by 30 % compared to previous-generation S Series devices. Depending on the application these products can deliver higher power density and achieve new levels of efficiency. Gate drive losses are also reduced due to the lower input capacitance of this new platform.
The 12 E Series devices released today include four 22 A MOSFETs and four 30 A MOSFETs with on-resistance of 190 mΩ and 125 mΩ, respectively, at 10 V. The 22 A and 30 A MOSFETs are available in the TO-220, TO-220 FullPAK, TO-247, and TO-263 (D2PAK) packages. In addition, one 47 A device with on-resistance of 64 mΩ at 10 V is offered in the TO-247 and a 24 A 650 V MOSFET with an on-resistance of 150 mΩ is offered in the TO-220, TO-263 (D2PAK), and TO-247 packages.
The ultra-low on-resistance of the E Series translates into extremely low conduction and switching losses to save energy in high-power, high-performance switch mode applications, including power factor correction, server and telecom power systems, welding, plasma cutting, battery chargers, high-intensity discharge (HID) lighting, fluorescent ballast lighting, semiconductor capital equipment, solar inverters, and induction heating.
The MOSFETs are compliant to RoHS Directive 2002/95/EC.
Samples of these new power MOSFETs are available today, with lead times of 16 to 17 weeks for production orders.
vishay.com
