The Infineon's CAN transceiver IFX1040SJ is a monolithic integrated circuit in a PG-DSO-8 package for high-speed differential mode data transmission (up to 1Mbaud) and reception in industrial applications.
IFX1040SJ serves as an interface between the CAN protocol controller and physical bus lines compatible with the ISO/DIS 11898 standard.
The transceiver delivers excellent passive behavior when it is switched off and supports remote wake-up capability via CAN bus in low-power mode, making it ideal for networks with partially un-powered nodes in energy-efficient industrial-grade system designs.
IFX1040SJ block diagram
Features
- CAN data transmission rate up to 1MBaud
- Compatible wtih ISO 11898-2 and ISO 11898-5
- Low-power mode with remote wake-up via CAN bus
- Wake signaling by RxD toggle
- No BUS load in stand-by mode
- Wide common mode range for electromagnetic immunity (EMI)
- Digital inputs compatible with 3.3V and 5V logic devices
- Split termination to stabilize the recessive level
- TxD time-out function
- Overtemperature protection
Applications
- Solar panel installations
- ECU networks for industrial automation
- Sensor networks (e.g. securitysystems, fire alarms)
- Battery-operated systems
