International Rectifier introduced the automotive-qualified AUIRS20302S three-phase gate driver IC for 12V, 24V and 48V vehicle applications including high-voltage air conditioner compressors, pumps, BLDC motor drives up to 600W and high-voltage motor drives.
The AUIRS20302S targets 12V, 24V and 48V boardnet automotive platforms operating at voltages up to 200V maximum. The new device features an external pre-regulator to generate its own supply voltage to ensure that the gate drives do not exceed 17V even during load dump conditions. The pre-regulator VPR pin can also supply the surrounding system components if the total consumption does not exceed 100mA.
The AUIRS20302S is capable of driving 6 N-channel power MOSFETs or IGBTs using a bootstrap technique to supply the high-side driving circuitry. The device also features embedded deadtime and cross-conduction prevention functions and under-voltage and over-current protection with diagnostics.
Proprietary HVIC and latch immune CMOS technologies enable ruggedized monolithic construction. The logic input is compatible with standard CMOS or LSTTL outputs, down to 3.3V logic. The output driver features a high pulse current buffer stage designed for minimum driver cross-conduction. Propagation delays are matched to simplify use in high frequency applications.
IR's automotive grade IC products are subject to dynamic and static part average testing combined with 100 percent automated wafer level visual inspection as part of IR’s automotive quality initiative targeting zero defects. The devices are qualified according to AEC-Q100 standards, feature an environmentally friendly, lead-free and RoHS compliant bill of materials.
Specifications
Part Number
Package
Topology
High Side
Supply Max Offset Voltage |
Vcc and Vbs
voltage range |
Output Source/
Sink Current |
Additional Features
AUIRS20302S
SOIC 28WB
3-phase gate driver
200V
8V-17V with Under
Voltage Lockout |
0.2A source;
0.35A Sink |
Pre-regulator
Current Sense Comparator Fault Logic |
