Atmel Showcases World's First Cortex-M4 Processor-Based Single-Chip Solution for PRIME Smart Metering Applications
Atmel SAM4SP32A
New Solution Delivers Unprecedented Level of System Integration, Low Power and High Performance Visit Atmel at the Metering Billing/CRM Europe Show in Booth #A31 in Amsterdam, Netherlands
Metering Billing/CRM Europe Show, Amsterdam, Netherlands - Atmel Corporation showcased the world's first single-chip power line communications (PLC)-based solution using an ARM Cortex-M4 processor-based microcontroller (MCU) targeting the rapidly growing PRIME smart metering market at the Metering Billing/CRM Show in Amsterdam.
Atmel's SAM4SP32A is a new compact, highly integrated solution that combines a Cortex-M4 processor-based MCU, 2MB of dual-bank Flash, 160KB SRAM and a high-performance PLC transceiver in a single-chip SoC that lowers overall system costs.
The SAM4SP32A SoC is fully compliant with the latest PRIME (Power Line Intelligent Metering Evolution) PLC specification.
In order to support the complex protocol required by smart meters to make firmware upgrades of the application and the protocol stack independently in the field, the new SoC integrates Atmel's PLC technology with a high-performance Cortex-M4 MCU with 2MB of program memory on a dual-bank configuration. The new solution also leverages the powerful peripherals of the Cortex-M4 MCU, including serial peripheral interface (SPI), TWI and USARTS, to support the various communication interfaces required by smart metering applications.
Atmel: SAM4SP32A Block Diagram
Atmel's SAM4SP32A SoC offers a high level of integration and power efficiency, along with extraordinary sensitivity of up to 34.8dBuV and a dynamic range of up to 73.18dB. The new SoC includes an integrated low-power amplifier that consumes 40 percent less power than other solutions on the market today.
Key Features
  • First ARM Cortex-M4 high-density PRIME system-on-chip solution running at up to 120MHz
  • 2MB dual-bank Flash to ease field firmware upgrades
  • 160KB SRAM
  • Best-in-class PRIME PLC modem
  • Highly efficient PLC line driver that consumes 40% less power than competitive devices
  • Less than 750mW power consumption in transmission mode
  • Sensitivity up to 34.8dBµV
  • Dynamic range up to 73.18dB
  • Peripherals including USB Device 2.0 Device, TWI, UARTs
Opitimizing the Design Process
To optimize the process of designing PLC-based smart metering solutions, the SAM4SP32A will be supported by Atmel Studio 6, the latest version of the company’s popular integrated development environment (IDE) that now supports both Atmel 32-bit ARM Cortex-M series processor-based and Atmel 8/32-bit AVR based microcontrollers (MCUs). For the first time, the extensive AVR customer base of more than 100,000 engineers and the designers of ARM Cortex-M series processor-based applications have all of the tools required to develop and debug Atmel MCU applications in a single, seamless environment. Atmel Studio 6 is available free of charge.
To further accelerate the design process, Atmel’s SAM4SP32A SoC will also available with a SAM4SP32AAEK-99 evaluation kit that includes two boards, a complete set of software libraries, application examples, a PHY tester, PRIME Network Manager and PC USI test. The evaluation kits will be available in Q1FY13.
Atmel SAM4SP32AAEK-99 Evaluation Kit
Availability
The Atmel SAM4SP32A SoC is sampling to lead customers now, with production quantities available in Q1FY2013. The SoC is available in a 128-lead LQFP package in a 14mm X 14mm dimension, with a 0.4mm pitch.
