TLE8718SA: Highly Flexible 18-Channel, Low-Side Switch Optimized for Powertrain Applications
Infineon TLE8718SA
Infineon's Flex multi-channel, low-side switches for powertrain, safety and industrial applications are specially designed to drive a wide range of loads. This all-round family concept combines full scalability (from two to eighteen channels) with leading-edge technology. All Flex multi-channel switches are equipped with proven, embedded protection functions and enhanced diagnostics for a wide range of platforms.
Infineon - TLE8718SA
TLE8718SA is the latest and most advanced addition to the Flex multi-channel switch family. It can drive a wide variety of inductive and resistive loads such as injectors, valves, relays, LEDs and O2 heaters. The high speed Micro Second Channel (MSC) interface reduces the number of control pins required, thus ensuring that the 18-channel device is ultra compact and has a high power density.
TLE8718SA is equipped with highly sophisticated protection and diagnosis features and tailored to the requirements of powertrain applications. Infineon's zero-defect excellence program for the automotive industry ensures the highest quality every time. Features
  • 18x low-side switches
    • 2x 0.20Ω @ 8.0A (high current)
    • 2x 0.35Ω @ 3.0A (dedicated disable)
    • 4x 0.72Ω @ 2.2A (dedicated disable)
    • 2x 0.47Ω @ 2.2A (high energy)
    • 4x 0.72Ω @ 2.2A
    • 2x 2.40Ω @ 0.6A (starter relays)
    • 2x 1.30Ω @ 0.6A
  • High-speed MSC interface
  • 2-bit diagnosis detection
    • Shortground
    • Open load
    • Short to battery / overtemperature
    • Normal operation
  • Protection
    • Overcurrent (configurable)
    • overtemperature + OT warning
    • Enhanced voltage monitoring
    • Bi-directional reset pin (ABE)
    • Reverse current detection
  • 55V internal active clamping
  • OUT15,16: Special functionality for starter relay
    • Operation down to 3V
    • Delayed switch OFF
  • OUT5-10 with dedicated disable pin for after-run
  • Programmable IN/OUT delay module
Applications
  • Automotive – powertrain
    • O2-heater (Inrush capable)
    • Injectors
    • Valves
    • Solenoids
    • Relays
    • Starter relays
    • LEDs
    • Multifunction indicator lamps (MIL)
  • Industrial applications with inductive or resistive loads
infineon-designlink.com
