IR Introduces IRS44273L Compact Low-Side Gate Drive IC in SOT-23-5L Package
International Rectifier IRS44273L
International Rectifier introduced the IRS44273L low-side gate drive IC offering high drive capability in a highly compact SOT-23-5L package.
The IRS44273L is easy to use and provides a simple solution for IGBT and MOSFET gate drive, offering 1.5A (typical) sink and source capability, fast switching performance and integrated under-voltage lockout protection with minimal board space requirements. This new device offers functionality previously only available in larger packages such as an SO-8 enabling more compact and economical system design.
International Rectifier - IRS44273L
The IRS44273L has two output pins on either side of the package to simplify system design by offering layout flexibility. The device has non-inverted inputs and is compatible with CMOS and LSTTL controllers.
Specifications
Part Number
Package
IO+ / IO-
(Typical)
TON / TOFF
(Typical)
Logic
IRS44273L
SOT23-5L
1.5A / 1.5A
50ns / 50ns
Non-Inverted
Availability and Pricing
Pricing for the IRS44273L begins at US$0.25 each in 10,000 unit quantities. Production quantities are available immediately. The devices are RoHS compliant and prices are subject to change.
irf.com
