Integrated Solution Features MOSFET and Diode in One Package, Simplifying Board Assembly and Saving Space
Fairchild Semiconductor optimizes the MOSFET and diode selection process by introducing a family of 100 V BoostPak devices that combines a MOSFET and diode in one package to replace discrete solutions currently used in LED TV / monitor backlight, LED lighting and DC-DC converter applications.
By integrating the MOSFET and diode into a single package, the FDD1600N10ALZD and FDD850N10LD devices save board space, simplify assembly, lower bill of material (BOM) costs and improve reliability of the application.
The devices feature an N-channel MOSFET produced using Fairchild’s PowerTrench® process that has been tailored to minimize the on-state resistance while maintaining superior switching performance. The NP diode is a hyperfast rectifier with low forward voltage drop and excellent switching performance. It has much lower leakage current than a Shottky diode, which improves system reliability in high temperature applications.
RDS(ON) = 124 mΩ (Typ.)@ VGS = 10 V, ID = 3.4 A
RDS(ON) = 175 mΩ (Typ.)@ VGS = 5 V, ID = 2.1 A
Low Gate Charge = 2.78 nC (Typ.)
Low Crss = 2.04 pF (Typ.)
RDS(ON) = 61 mΩ (Typ.)@ VGS = 10 V, ID = 12 A
RDS(ON) = 64 mΩ (Typ.)@ VGS = 5.0 V, ID = 12 A
Low Gate Charge = 22.2 nC (Typ.)
Low Crss = 42 pF (Typ.)
Fast switching
100% avalanche tested
Improved dv/dt capability
RoHS compliant
FDD1600N10ALZD: US$0.49
FDD850N10LD: US$0.57
