Vishay Intertechnology Introduces New Powdered-Iron-Based, WPC-Compliant Rx Coil for 7 V Charging Circuitry
Vishay IWAS-4832EC-50
New Wireless Charging Receiving Coil Works With or Without Alignment Magnet, Offers High Permeability Shielding and Efficiency Greater Than 75 %.
Vishay Intertechnology announced a new powdered-iron-based, WPC-compliant (Wireless Power Consortium) wireless charging receiving coil optimized for use with or without an alignment magnet. Offering a durable construction and high permeability shielding, the new IWAS-4832EC-50 provides high efficiency greater than 75 % for the wireless charging of 7 V portable electronics.
Vishay - IWAS-4832EC-50
The Vishay Dale Rx coil has been designed into a leading wireless power development kit. For higher voltage wireless power base stations and receivers, the IWAS-4832EC-50’s high-saturation powdered iron is not affected by permanent locating magnets, and the device blocks charging flux from sensitive components or batteries.
As an alternative to Ferrite-based solutions – which can saturate in the presence of a strong magnetic field – the IWAS-4832EC-50 has magnetic saturation of 50 % of inductance at 4000 gauss. The RoHS-compliant device features inductance of 16.2 μH at 200 kHz with a ± 5 % inductance tolerance, DCR of 366 mΩ at + 25 °C, and Q of 30 min. at 200 kHz. The device features a lead length of 50 mm and tinned length of 10 mm.
Samples and production quantities of the IWAS-4832EC-50 Rx coil are available now, with lead times of stock to six weeks.
vishay.com
