Avago Technologies introduces DC-50MBd miniature link fiber optic receiver with SMA port
Avago Technologies AFBR-2408Z
Avago Technologies released  AFBR-2408Z fiber optic receiver is designed to operate with the Avago Technologies HFBR-14xxZ fiber optic transmitters and multimode glass fiber cable. The receiver output is a digital CMOS/TTL signal. The AFBR-2408Z receiver contains an IC with integrated photodiode to convert the incoming optical signal to a digital output signal without requiring additional circuitry. Because of its integrated design, the receiver has very high EMC resistance. A wide receiver dynamic range and high sensitivity over temperature is achievable. The data rate goes from DC to 50MBd max. AFBR-2408Z is equipped with RSSI (Received Signal Strength Indication) feature, which delivers the signal strength of the incoming optical signal for diagnostic function.
Features
  • RoHS-compliant
  • Works with Avago HFBR-14xxZ (820nm LED) transmitter
  • Data transmission at signal rates from DC up to 50 MBd
  • Receiver: Integrated PIN diode and digitalizing IC with CMOS/TTL output logic
  • Up to 2 km distance with Multimode Glass Fiber Cable
  • Operating temperature range of -40°C to +85°C
  • 3.3 V and 5 V supply voltage operation
  • RSSI output
Applications
  • Optical transmission from DC up to 50 MBd
  • Industrial control and factory automation
  • High voltage isolation
  • Elimination of ground loops
  • Reduces voltage transient susceptibility
  • Power substation automation
Benefits
  • High Electromagnetic Interference (EMI) Immunity
  • High Voltage Isolation
  • High Data Security
  • Good Signal Integrity over Long Distance Transmission
  • Cost Effective Solution
avagotech.com
