Linear Technology Corporation introduces the LTC3875, a dual output curren tmode synchronous step-down DC/DC controller that enables the use of very low DC resistance (DCR) power inductors by using a novel DCR sensing architecture that enhances the signal-to-noise ratio of the current sense signal. Power inductor DCR, as low as 0.2 milliohms can be used without a sense resistor to maximize converter efficiency and increase power density. This new DCR sensing technique dramatically reduces the switching jitter normally associated with low DCR sensing applications.
The LTC3875 operates over an input voltage range of 4.5 V to 38 V and produces a fixed output voltage from 0.6 V to 3.5 V with ±0.5% accuracy from -40 °C to 125 °C. Dual onboard differential amplifiers provide true remote output voltage sensing of both output voltages. Up to 12 phases can be paralleled and clocked out-of-phase to minimize input and output filtering. When both outputs are paralleled, the LTC3875 maintains less than ±5% current mismatch between phases, making it ideal for very high current requirements up to 360 A. Precise programmable current sense limits and DCR temperature compensation limit the maximum output current precisely over temperature. Applications include high current power distribution, redundant (n+1) supplies, industrial systems, processor and ASIC power.
The LTC3875 has a selectable fixed operating frequency from 250 kHz to 720 kHz or it can be synchronized to an external clock. Powerful 1.1 Ohm onboard all N-channel gate drivers minimize MOSFET switching losses. Its adjustable current limit can be configured for very low sense voltages from 10 mV to 30 mV to minimize power loss. The second channel features a fast transient circuit that improves the load-step-up transient by up to 30%.
Additional features include adjustable soft-start or tracking, foldback current limit, short-circuit soft recovery, output overvoltage protection and a power good output voltage monitor.
The LTC3875 is available in a 40-lead 6 mm × 6 mm QFN package. The 1,000-piece price starts at $3.47 each.
