Analog Devices' NanoDAC+ Converters Expand Industry's Best D/A Converter Performance in the Smallest Package
Analog Devices
Analog Devices, Inc. (ADI) introduced the AD5683R D/A converter. This16-bit single nanoDAC+ continues the series of ADIs nanoDAC® products offering high performance in smaller packages. Offering value without compromise with relative accuracy of ±2-LSB INL, 2-ppm/°C 2.5-V reference, and space saving packages, this combination allows analog designers to address a wider range of applications without having to trade accuracy for footprint.
Analog Devices - AD5683R
With 16, 14, 12 and 10-Bit options available, the AD5683R D/A converter provides a versatile pin-compatible upgrade/downgrade path for performance in a wide range of markets including communications infrastructure, industrial process control, healthcare and instrumentation.
AD5683R 16-bit nanoDAC + Key Features:
  • ±2 LSB-INL max – suits open loop applications
  • 2-ppm/°C 2.5-V reference – saves board space and removes calibration requirements over temperature
  • Total Unadjusted Error 2-mV – eliminates need for initial calibration/adjustment
  • 2-mm × 2-mm 8-lead LFCSP and 10-lead MSOP – allowing more functionality within shrinking board/module sizes
  • 4-KV HBM ESD rating - provides system robustness
  • I2C versions available soon
Pricing and Availability
Product
Sample Availability/
Full Production
Resolution
Integrated
Reference
Interface
Price Each
Per 1,000
Packaging
AD5683R
NOW
16-bit
Yes
SPI
$3.15
8-lead LFCSP,
10-lead MSOP
AD5683
NOW
16-bit
No
SPI
$2.50
8-lead LFCSP
AD5682R
NOW
14-bit
Yes
SPI
$2.30
8-lead LFCSP
AD5681R
NOW
12-bit
Yes
SPI
$1.90
8-lead LFCSP,
10-lead MSOP
AD5310R
NOW
10-bit
Yes
SPI
$1.29
10-lead MSOP
The AD5683R can be designed into circuits for PLC, I/O cards applications with ADI’s AD5750-2 which is a single-channel, low cost, precision voltage/current output driver amplifier.
analog.com
