Half to full watt LED has 30 V version available, other voltages upon request
Everlight Electronics announces the XI3030 High Voltage series, an addition to EVERLIGHT’s popular XI3030 mid to high power LED package. By introducing the High Voltage version, a new concept of the existing XI3030 series with higher voltages at a lower price, aims at reducing manufacturers’ total lamp or fixture costs. The XI3030 HV LED is a half to full watt LED that has a 30 V version available, with other voltages upon request.
High Voltage LEDs, when used correctly, simplify driver designs by reducing the voltage difference between the AC input line voltage of the completed product and the DC input voltage to the LED components. This not only reduces the number and cost of driver components needed but improves driver efficiency. Thus producing a more efficient, more cost effective total solution.
The performance level of EVERLIGHT’s new high voltage XI3030 HV series meets all application requirements and achieves an efficiency of around 120 lm/W at 3000K CCT, 80Ra minimum and 115 lm brightness. It is available either with 7-step ANSI-bin or 3-step central bin. Reliability testing has undergone up to 3000 hours internally at EVERLIGHT and LM80 is under process. EVERLIGHT’s XI3030 package is Pb-free, halogen-free and RoHS compliant.
In line with EVERLIGHT’s campaign of “The Right LED for the Right Application”, the XI series High Voltage LED can be used as different cluster configurations in applications such as LED bulbs, LED lamps, LED down lights, and LED flood lights to optimize cost versus performance of each of those applications.
