Toshiba Introduces New Low-Height Transistor Output Photocoupler
Toshiba TLP385
Offers Wider Creepage Distance; Suited to Applications with Strict Height Requirements
Toshiba America Electronic Components, Inc. (TAEC) announced the launch of a new transistor output photocoupler in a low-height SO6L 4 pin package – the TLP385. With its low-height of 2.3 mm (max), 45 percent lower than DIP4 packages, the TLP385 can be used in situations with strict height requirements. Applications including motherboards, programmable logic controllers, AC adapters, I/O interface boards, inverter interfaces and general purpose power supplies are suited to the new photocouplers.
Toshiba - TLP385
Toshiba's new photocoupler has an isolation specification equivalent to DIP4 F (wide lead) type package products, and provides a creepage and clearance distance of 8 mm (min) and isolation voltage of 5 kVrms (min).
Key Specifications
  • Current Transfer Ratio (CTR): 50 to 600%@IF = 5 mA, VCE = 5 V
  • Turn-off (tOFF): 40 µs (typ.) @IF = 16 mA
  • Operating Temperature Range (Topr): –55 to 110 °C
  • Isolation Voltage (BVS): 5 kVrms
  • Safety Standard: UL, cUL, VDE, CQC
The new transistor output photocouplers are available now. For more details, samples and pricing information, please contact your local Toshiba Sales Office.
toshiba.com
