NVE Corporation has introduced 2.5 kV isolation versions of its IsoLoop® IL700-1 Series MSOP Isolators, the world’s smallest isolators. The new versions are designated with a “V-1” suffix.
World’s Smallest
With JEDEC-standard 3 millimeter by 3 millimeter MSOP-8 packages, IsoLoop® IL700-1 Series Isolators are the world’s smallest isolators. Until now they were only available with 1 kV isolation ratings.
Exceptional Specifications
To meet the full industry-standard 2.5 kVrms isolation specification, V-1 MSOP Isolators are 100% tested to withstand 3 kVrms, which is unprecedented for such a small part.
Other V-1 series MSOP specification highlights are:
- One and two channels; unidirectional and bidirectional
- 110 megabits per second
- 2.5 kVrms isolation (1 minute) per UL 1577
- 600 Working Voltage (line voltage) per VDE 0884-10
- 100 teraohm minimum barrier resistance
- -40°C to +100°C operating temperature
- 44000 year barrier life
- 3 millimeters creepage
Available Now
All three part types are in stock for immediate delivery:
- The one-channel IL710V-1E
- The two-channel (both same direction) IL711V-1E
- The two-channel (one each direction) IL712V-1E
Suggested pricing is $2.75 each in quantities of 1000 for the single-channel IL710V-1E, and $4.46 for the IL711V-1E and IL712V-1E two-channel parts.
The original MSOP versions with 1 kV isolation will continue to be available for applications not requiring safety isolation.
