TI introduces the first brushed DC motor driver with integrated current sensing
Texas Instruments DRV8871 DRV8870 DRV8872
Motor driver family with integrated FETs simplifies design and saves power for 12- and 24-V motors
Texas Instruments introduced a family of three brushed DC gate drivers featuring the industry's first device with integrated current sensing. With this integration, designers using the DRV8871 can avoid the power loss, heat generation and cost associated with using external sense resistors. Compared to competitive devices, the DRV8871 motor driver family helps reduce design complexity, power consumption and board space in end equipment such as multifunction printers, appliances and industrial machines.
Texas Instruments - DRV8871
Expanding TI's brushed DC motor driver portfolio, the DRV8871 is one of three new brushed DC drivers with integrated field-effect transistors (FETs), developed for space-constrained designs. The DRV8870 features integrated regulation to limit current to an external current-sense resistor. The DRV8872 provides fault monitoring to increase system reliability.
Key features and benefits
  • Reduced system complexity:
    When designing with the DRV8871, the elimination of discrete sense resistors reduces board space by up to 25 percent.
  • Optimal power consumption:
    The devices use standard low-cost, low-power resistors to set the current threshold, limiting startup and stall inrush currents. The ability to limit current to a known level can significantly reduce the system power requirements and bulk capacitance needed to maintain a stable voltage, especially for motor startup and stall conditions.
  • Simplified design:
    Board layout with accurate current regulation is simplified because no sense routing is required with the DRV8871.
  • Wide supply range:
    The devices offer a wide 6.5- to 45-V motor-supply voltage to support industry-standard 12- and 24-V supplies.
DRV8871 Features:
  • H-Bridge Motor Driver
    • Drives One DC Motor, One Winding of a Stepper Motor, or Other Loads
  • Wide 6.5-V to 45-V Operating Voltage
  • 565-mΩ Typical RDS(on) (HS + LS)
  • 3.6-A Peak Current Drive
  • PWM Control Interface
  • Current Regulation Without a Sense Resistor
  • Low-Power Sleep Mode
  • Small Package and Footprint
    • 8-Pin HSOP With PowerPAD 4.9 × 6.0 mm
  • Integrated Protection Features
    • VM Undervoltage Lockout (UVLO)
    • Overcurrent Protection (OCP)
    • Thermal Shutdown (TSD)
    • Automatic Fault Recovery
Tex Instruments: DRV8871 Block Diagram
Click to enlarge
Tools and support
The DRV8870EVM, DRV8871EVM and DRV8872EVM evaluation modules (EVMs) demonstrate the capabilities and performance of their respective brushed DC motor drivers. The EVMs also incorporate the TPS7A16 low-dropout regulator (LDO) and the TLC555 low-power timer. They are available for purchase for US$49 via the TI store and authorized distributors.
DRV8870 H-Bridge PWM Motor Driver Evaluation Module
DRV8870 H-Bridge PWM Motor Driver Evaluation Module.
Pricing and availability
The 8-pin DRV8871 family is available now in a 4.9-mm-by-6.0-mm thermally enhanced small outline package (HSOP). Pricing in 1,000-unit quantities starts at US$1.40 for the DRV8871 and US$1.28 for the DRV8870 and DRV8872.
