New X400 Client SSD Delivers Faster Response, Longer Battery Life and Outstanding Reliability for Consumers Upgrading to Ultra-thin Computing Systems
SanDisk Corporation announced availability of the new SanDisk® X400 SSD, the world’s thinnest one terabyte (1 TB) M.2 solid state drive (SSD). It is the first single-sided 1 TB SATA M.2 form factor with a mere 1.5 mm height. The X400 SSD is designed for fast start-up and application launch, as well as for extended battery life. Consumer research conducted by SanDisk in late 2015 indicates that these benefits are important for more than 70% of consumers when using PCs.
Designed for High Reliability
Both consumer and enterprise PC users can expect exceptional reliability even with heavy use. For example, in testing, a 256GB X400 SSD was rated to operate for more than 5 years with a workload of approximately 40 GB/day. This performance makes the X400 SSD an optimal solution for enterprise or other OEM customers who need a highly reliable solution for systems that are broadly deployed in the field, such as digital signage, networking gear, point of sale (POS), and commercial PCs.
The X400 SSD also achieves increased reliability and endurance by implementing SanDisk’s own nCache™ 2.0 technology and DataGuard™ technology as well as additional error correction mechanisms. Based on SanDisk’s 6th generation X3 Technology, the SanDisk X400 SSD uses 90% less power than a traditional hard disk drive. Consumers that upgrade to the X400 SSD will now have the luxury of working longer without a power source, and enjoying faster response times while moving data more efficiently.
In addition, the X400 SSD offers data protection through AES 256-bit compliant encryption and TCG Opal 2.0 compatibility, targeting users in the healthcare, financial services and education sectors who need to be compliant with industry regulations.
The SanDisk X400 SSD is currently available in 2.5’’ cased and M.2 2280 form factors at 128 GB, 256 GB, 512 GB and 1 TB capacities.
