Maxim Introduces New 1Gbps to 10Gbps Preemphasis Driver with Receive Equalizer
Maxim MAX3984
The MAX3984 is a single-channel, preemphasis driver with input equalization that operates from 1Gbps to 10.3 Gbps. It provides compensation for copper links, such as 8.5 Gbps Fibre Channel and 10.3 Gbps Ethernet, allowing spans of up to 10 m with 24 AWG cable. The driver provides four selectable preemphasis levels, and the selectable input equalizer compensates for up to 10in of FR-4 circuit board material at 10 Gbps.
The MAX3984 also features SFP-compliant loss-of-signal (LOS) detection and TX_DISABLE. Selectable output swing reduces EMI and power consumption. The MAX3984 is packaged in a lead-free, 3 mm x 3 mm, 16-pin thin QFN and operates from a 0°C to +85°C temperature range.
  • Drives Up to 10 m of 24 AWG Cable
  • Drives Up to 30 in of FR-4
  • Selectable 1000mVP-P or 1200mVP-P Differential Output Swing
  • Selectable Output Preemphasis
  • Selectable Input Equalization
  • LOS Detection with Built-In Squelch
  • Transmit Disable
