Analog Devices MEMS Accelerometers Deliver Compelling Noise Performance for Condition Monitoring Applications
Analog Devices ADXL1001 ADXL1002
Analog Devices announced two new high frequency, low noise MEMS accelerometers designed explicitly for industrial condition monitoring applications. The ADXL1001 and ADXL1002 MEMS accelerometers deliver the high resolution vibration measurements necessary for early detection of bearing faults and other common causes of machine failure. Historically, inadequate noise performance of available high frequency MEMS accelerometers compared with legacy technology held back adoption, failing to take advantage of MEMS reliability, quality and repeatability. Today, the ADXL1001/ ADXL1002 noise performance over high frequencies, on par with available PZT technology, make ADI MEMS accelerometers a compelling option for new condition monitoring products. The ADXL1001 and ADXL1002 are the latest examples of high performance precision sensing technology from Analog Devices, providing high quality and accurate data for Smart Factory IoT applications, enabling intelligent sensing from the edge of the network.
Analog Devices - ADXL1001, ADXL1002
More about the ADXL1001 and ADXL1002
ADXL1001/ADXL1002 MEMS accelerometers deliver ultra-low noise density over an extended bandwidth with high-g range. The accelerometers are available in two models, with full-scale ranges of ±100g (ADXL1001) and ±50g (ADXL1002). Typical noise density for the ADXL1002 is 25 μg/√Hz, with a sensitivity of 40 mV/g, and 30 μg/√Hz for ADXL1001, with sensitivity 20 mV/g. Both accelerometers operate on single voltage supply from 3.0 V to 5.25 V, and offer useful features such as complete, electromechanical self-test and over range indicator. The ADXL1001/ADXL1002 are available in a 5 mm × 5 mm × 1.85 mm LFCSP package and are rated for operation over a –40 °C to +125 °C temperature range.
ADXL1001/ADXL1002 Evaluation Board EVAL-ADXL100X
ADXL1001/ADXL1002 Evaluation Board EVAL-ADXL100X.
Product Pricing and Availability
Product Output
Interface
Full-scale
Range
Product
Availability
Price Each
per 1,000
Packaging
ADXL1001 Analog ±100 g Now $29.61 32 lead 5×5 mm LFCSP
ADXL1002 Analog ±50 g Now $29.61 32 lead 5×5 mm LFCSP
