Mean Well Introduces 1000W Single Output DC-DC Converter
Mean Well SD-1000
Mean Well launches the SD-1000 series (1000 W) enclosed type DC/DC converter that expands our SD product lines to higher wattage range for the growing demand of high wattage DC/DC applications. Featuring 4:1~2:1 wide DC input range and 2000VAC input/output isolation, SD-1000 series have two kinds of DC input level – 19~72 V (L type), 72~144 V (H type) and three kinds of DC output level – 12 V, 24 V, 48 V for end users to select from. With built-in short circuit, overload, over voltage and over temperature protections, these 1 U low profile converters are suitable for general electrical engineering usage, automotive, and battery back-up applications which have space constraint and required a compact DC/DC power solution. Other standard function includes 12 V / 0.25 A auxiliary output, output OK signal, remote ON/OFF control, and remote sense function that can fit in with many possible special end applications.
Mean Well SD-1000
