Analog Devices' Plug-and-Play Antenna Chip Simplifies Phased Array Radar for Avionics and Communications Equipment Designers
Analog Devices ADAR1000
Analog Devices introduced a highly integrated, active antenna beamforming chip that allows designers to quickly replace bulky, mechanically steered antenna platforms with a compact, solid-state solution for phased array radar and communications systems. The ADAR1000 chip simplifies design and significantly reduces the size, weight and power of phased array radar systems for defense, surveillance, air traffic control, communications and weather monitoring. For avionics designers, the ADAR1000 enables flat-panel antenna arrays, which shrinks the profile of conventional radar systems and facilitates the design of smaller, lighter aircraft. The new ADAR1000 is a plug-and-play chip that allows designers with little or no RF experience to extend the performance and operating lifetime of their radar systems.
Analog Devices - ADAR1000
The 4-channel ADAR1000 active antenna beamforming chip replaces 12 discrete components needed for antenna phase-gain adjustments and digital controls. The IC supports time division duplexing (TDD) across the X and Ku bands. It includes an integrated T/R switch that can be used to select the common port as an input for transmit (Tx) or an output for receive (Rx). The four pairs of Tx and Rx channels have independently programmable gain and phase settings. The ADAR1000 can be configured to directly control all aspects of external T/R module pulsing with minimal extra circuitry. All settings can be loaded into built-in memory for fast access to gain-phase states and T/R module settings. The ADAR1000 offers a scalable building block for fast implementation of active antenna phased arrays targeting next-generation radar and communications systems without the need for extensive third-party design support.
ADAR1000 Active Antenna Beamforming Chip Product Features
  • 8-GHz to 16-GHz frequency range
  • Half-duplex TDD for Tx and Rx
  • Single-pin Tx/Rx control
  • Versatile T/R modules control modes
  • 360-degree phase control with less than 2.8-degree phase resolution
  • Greater than 31-dB gain control with 0.5-dB resolution
  • On-chip memory for pre-stored beam positions
  • Auxiliary 8-bit A/D converter for power detectors and temperature sensor
  • Support for low-power modes
  • 4-wire SPI interface
Product Pricing and Availability
Product Sample Availability Full Production Price Each per 1,000 Packaging
ADAR1000 May 2018 June 2018 Contact ADI at
adar1000@analog.com
7 mm × 7 mm LGA package
ADAR1000-EVALZ
Evaluation Board
N/A May 2018 Contact ADI at
adar1000@analog.com
N/A
The ADAR1000-EVALZ Evaluation Board
The ADAR1000-EVALZ Evaluation Board.
