MAX22445 enables safe, high-throughput and compact industrial automation systems
To better protect industrial systems from the dangers of high-voltage signals, equipment designers can now turn to the new robust and reliable MAX22445 5 kVRMS four-channel reinforced digital isolator from Maxim Integrated. Delivering up to 2x greater throughput at 4x lower power consumption versus competing solutions, the MAX22445 provides reliable communication across the isolation barrier to ensure safe operation of compact industrial, medical and other equipment.
In high-voltage equipment, digital isolators provide signal isolation and level-shifting for proper operation of many circuits, while also protecting users from dangers such as electric shock. Yet, not all of these isolators are alike as many consume a large amount of power, generate significant heat and introduce large propagation delays, limiting system reliability and throughput.
Overcoming the shortcomings of other digital isolators, the MAX22445 delivers reinforced, dual insulation barrier isolation for fast digital signals. The IC, which mitigates the dangers of high-voltage power, transfers signals of up to 200 Mbps with significantly less power than competitive solutions. It is available in a 16-pin wide-body SOIC package with 8 mm of creepage and clearance.
Key Advantages
- Low Power:
0.41 mA per channel current consumption and 0.74 mW power consumption at 1 Mbps with VDD at 1.8 V. The IC has 4x lower power consumption compared to competing solutions while also reducing heat generation and enabling reliable and compact designs.
- High Speed:
Maximum propagation delay of 10.5 ns and maximum data rate of 200 Mbps enable fast and accurate data acquisition and high-speed interfaces with wide timing margins. The IC delivers up to 2x greater throughput versus other available solutions.
- Robust and Reliable:
Dual barriers of isolation provide 5 kVRMS and 10 kV surge for reliable performance over a long product lifetime and meet the safety standards required for operator protection.
Availability and Pricing
The MAX22445 is available at Maxim's website for $3.49 (1000-up, FOB USA); also available from select authorized distributors
The MAX22445FWEVKIT# evaluation kit is available for $32 (FOB USA)
The MAX2244XWEVKIT#: Evaluation Kit for the MAX22444/ MAX22445/MAX22446. |
