USB Type-C Port Switch from Diodes Incorporated Enables Latest Mobile Devices to Continue Supporting Legacy Data and Audio Signals
Diodes PI3A6386
Diodes Incorporated announced the PI3A6386 USB Type-C™ multimedia port switch, designed to enable manufacturers to continue supporting legacy data and analog peripherals through USB Type-C ports. As a result of the adoption of USB Type-C ports in mobile phones and tablets, manufacturers are removing other ports such as USB 2.0 and 3.5 mm audio sockets. The PI3A6386 port switch enables legacy data and audio signals to be passed through the USB Type-C port, allowing consumers to continue using existing peripherals.
Diodes - PI3A6386
The performance of the PI3A6386 port switch ensures a high level of audio quality, without signal distortion or noise. It includes autonomous microphone and ground line switching, while its CMOS design delivers an ON resistance of just 1 Ω for the audio switching transistor. Low crosstalk between data and audio channels was also a design priority for the PI3A6386, and it succeeds here with a crosstalk rejection of -85 dB at 30 kHz.
Other design features include a programmable soft-start and soft-stop time, which eliminates the pop and click that audio signals can experience when they are DC-coupled. This delivers an audio experience free from distortion. The PI3A6386 operates from a supply of between 1.7 V and 5.5 V, making it suitable for portable devices. It can also process signals of ±3 V, which further improves the dynamic range and audio quality.
The PI3A6386 supports USB 2.0 High Speed and Full Speed signals and USB Type-C Audio Accessory Mode. The THD of –110 dB is maintained from 20 Hz to 20 kHz with a signal of 2.0 V RMS into a 32 Ω load. Separate ground switches are also used for the audio and data signals, to further minimize crosstalk.
The PI3A6386 is available in the TQFN-24 package.
