Texas Instruments Introduced a Simple 4.3-V to 17-V Input, 2-A Synchronous Buck Converter in SOT563
Texas Instruments TPS562207
Texas Instruments (TI) introduced a simple, easy-to-use, 2-A synchronous buck converter TPS562207 in a SOT563 package. The device is optimized to operate with minimum external component counts and also optimized to achieve low standby current.
Texas Instruments - TPS562207
This switch mode power supply (SMPS) device employs D-CAP2 mode control providing a fast transient response and supporting both low equivalent series resistance (ESR) output capacitors such as specialty polymer and ultra-low ESR ceramic capacitors with no external compensation components.
The TPS562207 Simplified Application Schematic
The TPS562207 Simplified Application Schematic.
TPS562207 operates in Forced Continuous Conduction Mode (FCCM), which maintains fixed switching frequency and output voltage ripple is very small. TPS562207 is available in a 6-pin 1.6-mm × 1.6-mm SOT563 (DRL) package, and specified from a –40 °C to 125 °C junction temperature.
TPS562207 Efficiency vs. Load Current
TPS562207 Efficiency vs. Load Current.
Features
  • 2-A converter integrated 145-mΩ and 86-mΩ FETs
  • D-CAP2™ Mode Control with fast transient response
  • Input voltage range: 4.3 V to 17 V
  • Output voltage range: 0.8 V to 7 V
  • Forced continuous conduction mode
  • 590-kHz switching frequency
  • Low shutdown current less than 3 μA
  • 2% feedback voltage accuracy (25 °C)
  • Support pre-bias function
  • Cycle-by-cycle overcurrent limit
  • Hiccup-mode overcurrent protection
  • Non-latch UVP and TSD protections
  • Fixed soft start: 1.0  ms
Applications
  • Digital TV power supply
  • Smart speaker
  • Wired networking
  • Digital set top box (STB)
  • Surveillance
TPS562207EVM 2-A, Synchronous Step-down Converter Evaluation Module
Evaluation Module.
