IXYS launches mass production of new SiC MOSFET and IGBT driver
IXYS IX4351NE
IXYS, a division of Littelfuse, has begun mass production of the IX4351NE IC, designed to drive SiC MOSFETs and high power IGBTs. Separate 9 A source and sink outputs allow for tailored turn-on and turn-off timing while minimizing switching losses. An internal negative charge regulator provides a selectable negative gate drive bias for improved dV/dt immunity and faster turn-off.
IXYS - IX4351NE
Desaturation detection circuitry detects an over current condition of the SiC MOSFET and initiates a soft turn off, thus preventing a potentially damaging dV/dt event. The logic input, IN, is TTL and CMOS compatible; this input does not need to be level shifted even with a negative gate drive bias voltage. Protection features include UVLO and thermal shutdown detection. An open drain FAULT output signals a fault condition to the microcontroller.
The IX4351NE is rated for an operational temperature range of –40 °C to +125 °C, and is available in a thermally enhanced 16-pin power SOIC package.
Features
  • Separate 9 A peak source and sink outputs
  • Operating Voltage Range: –10 V to +25 V
  • Internal charge pump regulator for selectable negative gate drive bias
  • Desaturation detection with soft shutdown sink driver
  • TTL and CMOS compatible input
  • Under Voltage lockout (UVLO)
  • Thermal shutdown
  • Open drain FAULT output
Applications
  • Driving SiC MOSFETs and IGBTs
  • On-board charger and DC charging station
  • Industrial inverters
  • PFC, AC/DC and DC/DC converters
IX4351 Evaluation Board
IX4351 Evaluation Board.
