Product brochure RTC1000 oscilloscope (Rohde&Schwarz) - 6
ManufacturerRohde&Schwarz
DescriptionOscilloscope
Pages / Page12 / 6 — Oscilloscope. Logic analyzer. Protocol analyzer. Waveform and pattern …
Revision04.00
Oscilloscope. Logic analyzer. Protocol analyzer. Waveform and pattern generator
Oscilloscope Logic analyzer Protocol analyzer Waveform and pattern generator
X-in-1 oscilloscope
Oscilloscope
With a sampling rate of up to 2 Gsample/s and a memory depth of up to 2 Msample, the R&S®RTC1000 oscilloscope excels in its class. A waveform up- date rate of more than 10 000 waveforms/s ensures a responsive instrument that reliably catches signal faults. Included tools provide quick results, e.g. QuickView, mask tests, FFT, math, cursors and automatic measurements (including statistics).
Logic analyzer
The R&S®RTC-B1 option turns every R&S®RTC1000 into an intuitive-to-use MSO with 8 additional digital channels. The oscilloscope captures and analyzes sig- nals from analog and digital components in an embedded design – synchro- nously and time-correlated to each other. For example, the delay between the input and output of an A/D converter can be conveniently determined using the cursor measurements.
Protocol analyzer
Protocols such as I2C, SPI and CAN/LIN frequently transfer control messages between integrated circuits. The R&S®RTC1000 has versatile options for proto- col-specific triggering and decoding of serial interfaces. Selective acquisition and analysis of relevant events and data is possible. With the hardware-based implementation, smooth operation and a high update rate are ensured even for long acquisitions. This is advantageous, for example, for capturing multiple packetized serial bus signals.
The integrated R&S®RTC-B6 waveform and pattern generator up to 50 Mbit/s is useful for educational purposes and for implementing prototype hardware. In addition to common sine, square/pulse, ramp and noise waveforms, it outputs 4-bit patterns. Waveforms and patterns can be imported as CSV files or copied from oscilloscope waveforms. You can preview signals before playing them back to quickly check signal correctness. Predefined patterns for e.g. I2C, SPI, UART and CAN/LIN are provided.
6
RTC1000_bro_en_3607-4287-12_v0400.indd 6 10.01.2018 12:25:18
