Datasheet DH-IPC-HDW4421E(-AS) (Dahua Technology) - 3
Manufacturer | Dahua Technology |
Description | 4MP HD WDR Network Small IR Dome Camera |
Pages / Page | 5 / 3 — DH-IPC-HDW4421E(-AS). Network. Auxiliary Interface. General |
File Format / Size | PDF / 590 Kb |
Face detect Ethernet RJ-45 (10/100Base-T)
Network
Wi-Fi N/A Protocol IPv4/IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS, Bonjour, 802.1x Compatibility ONVIF, PSIA, CGI Max. User Access 20 users Smart Phone iPhone, iPad, Android, Windows Phone
Auxiliary Interface
Memory Slot Micro SD Max 128GB(only for -AS) RS485 N/A Alarm N/A PIR Sensor Range N/A
General
Power Supply DC12V, PoE (802.3af) Power Consumption Max 3.7W Working Environment -30°C~+60°C, Less than 95% RH Ingress Protection IP67 Vandal Resistance N/A Dimensions Φ 110mm× 95mm Weight 0.32kg
