Texas instruments: MSP430FR57XX Products Lineup
Texas Instruments MSP430FR573X MSP430FR572X
The MSP430FR57xx is the industry's first ultra-low power microcontroller with embedded FRAM from Texas Instruments. Realize never-before-seen power consumption, performance, and flexibility with this next-generation embedded memory technology. MSP430FR57xx devices will propel innovation, enabling developers to demand more from their designs and also create new applications.
The Texas Instruments MSP430 family of low-power microcontrollers consists of several devices featuring different sets of peripherals targeted for various applications. The architecture, combined with seven low-power modes is optimized to achieve extended battery life in portable measurement applications. The device features a powerful 16-bit RISC CPU, 16-bit registers, and constant generators that contribute to maximum code efficiency.
Texas Instruments - FRAM - MSP430FR57xx
The MSP430FR572x and MSP430FR573x devices are microcontroller configurations with up to five 16-bit timers, comparator, universal serial communication interfaces (eUSCI) supporting UART, SPI, and I2C, hardware multiplier, DMA, real-time clock module with alarm capabilities, up to 33 I/O pins, and an optional high-performance 10-bit analog-to-digital converter (ADC). Family members available are summarized in Table 1.
FEATURES
  • Embedded Non-Volatile FRAM
    • Supports Universal Memory
    • Ultra-Fast Ultra-Low-Power Write Cycle
    • Error Correction Coding (ECC)
    • Memory Protection Unit
  • Low Supply Voltage Range, 2.0 V to 3.6 V
  • 16-Bit RISC Architecture, Up to 24-MHz
  • Low Power Consumption
    • Active Mode (AM): All System Clocks Active 103 µA/MHz at 8 MHz, 3.0 V, FRAM Program Execution (Typical), 60 µA/MHz at 8 MHz, 3.0 V, RAM Program Execution (Typical)
    • Standby Mode (LPM3):
      • Real-Time Clock With Crystal , Watchdog, and Supply Supervisor Operational, Full System State Retention: 6.4 µA at 3.0 V (Typical)
      • Low-Power Oscillator (VLO), General-Purpose Counter, Watchdog, and Supply Supervisor Operational, Full System State Retention: 6.3 µA at 3.0 V (Typical)
    • Off Mode (LPM4): Full System State Retention, Supply Supervisor Operational:5.9 µA at 3.0 V (Typical)
    • Real-Time Clock Mode (LPM3.5): 1.5 µA at 3.0 V (Typical)
    • Shutdown Mode (LPM4.5): 0.32 µA at 3.0 V (Typical)
  • Power Management System
    • Fully Integrated LDO
    • Supply Voltage Supervision and Brownout
  • Clock System
    • Factory Trimmed DCO With Three Selectable Frequencies
    • Low-Power/Low-Frequency Internal Clock Source (VLO)
    • 32-kHz Watch Crystals and High-Frequency Crystals up to 24 MHz
  • 16-Bit Timer TA0, Timer_A With Three Capture/Compare Registers
  • 16-Bit Timer TA1, Timer_A With Three Capture/Compare Registers
  • 16-Bit Timer TB0, Timer_B With Three Capture/Compare Shadow Registers
  • 16-Bit Timer TB1, Timer_B With Three Capture/Compare Shadow Registers
  • 16-Bit Timer TB2, Timer_B With Three Capture/Compare Shadow Registers
  • Enhanced Universal Serial Communication Interfaces
    • eUSCI_A0 and eUSCI_A1 Each Supporting
      • Enhanced UART supporting Auto-Baudrate Detection
      • IrDA Encoder and Decoder
      • Synchronous SPI
    • eUSCI_B0 Supporting
      • I2C With Multi-Slave Addressing
      • Synchronous SPI
  • 10-Bit Analog-to-Digital (A/D) Converter With Internal Reference, Sample-and-Hold
  • On-chip Comparator
  • Hardware Multiplier Supporting 32-Bit Operations
  • Three Channel Internal DMA
  • Real-Time Clock with Calendar and Alarm Functions
  • Serial Onboard Programming, No External Programming Voltage Needed
Ultra-low-power Read/Write With Increased Throughput
MSP430 devices with embedded FRAM are cutting the industry’s best active power consumption by half, achieving sub-100μA/MHz. Read and writes require just 1.5V, so it is able to operate without a charge pump, unlike Flash and EEPROM. This lowers power and minimizes physical footprint.
FRAM consumes 250x less power than Flash-based devices when running at equal speed (12kB/s)
True Unified Memory
FRAM is uniquely flexible offering developers the ability to use the same memory block to function as program memory or data memory. With FRAM, developers can dynamically partition the memory depending on the current stage of the user’s development cycle. This feature allows faster time to market and simplified inventory control – one single device can be dynamically configured into various memory configurations.
FRAM’s unified memory block can be dynamically configured as program, data or info memory providing unmatched flexibility.
Industry-Leading Read/Write Speeds
In addition to lower power performance, FRAM can also maintain unmatched data throughput. MSP430 with embedded FRAM is capable of 50ns access times, enabling speeds up to 1400 kB/s. With FRAM, embedded memory is no longer the bottle neck of your application.
FRAM can write more than 100x faster than flash, while consuming less power!
Table 1. MSP430FR57xx Family Members
Device
FRAM
(KB)
SRAM
(KB)
System
Clock
(MHz)
eUSCI
(UART/IrDA/SPI) /
(SPI/I2C)
ADC10_B
ext/int
Comp_D
(ch)
IO
Package
MSP430FR5739
16
1
24
2/1
12/2
16
32
40-VQFN
30 38-TSSOP
MSP430FR5738
16
1
24 1/1
6/2
10
17
24-VQFN
8/2 12 21 28-TSSOP
MSP430FR5737
16
1
24 2/1
16
32
40-VQFN
30 38-TSSOP
MSP430FR5736
16
1
24 1/1
10
17
24-VQFN
12 21 28-TSSOP
MSP430FR5735
8
1
24 2/1
12/2
16
32
40-VQFN
30 38-TSSOP
MSP430FR5734
8
1
24 1/1
6/2
10
17
24-VQFN
8/2
12 21 28-TSSOP
MSP430FR5733
8
1
24 2/1
16
32
40-VQFN
30
38-TSSOP
MSP430FR5732
8
1
24 1/1
10
17
24-VQFN
12 21 28-TSSOP
MSP430FR5731
4
0.5
24 2/1
12/2
16
32
40-VQFN
30 38-TSSOP
MSP430FR5730
4
0.5
24 1/1
6/2
10
17
24-VQFN
8/2 12 21 28-TSSOP
MSP430FR5729
16
1
8
2/1
12/2
16
32
40-VQFN
30 38-TSSOP
MSP430FR5728
16
1
8 1/1
6/2
10
17
24-VQFN
8/2
12 21 28-TSSOP
MSP430FR5727
16
1
8 2/1
16
32
40-VQFN
30 38-TSSOP
MSP430FR5726
16
1
8 1/1
10
17
24-VQFN
12 21 28-TSSOP
MSP430FR5725
8
1
8 2/1
12/2
16
32
40-VQFN
30 38-TSSOP
MSP430FR5724
8
1
8 1/1
6/2
10
17
24-VQFN
8/2
12 21
28-TSSOP
MSP430FR5723
8
1
8 2/1
16
32
40-VQFN
30 38-TSSOP
MSP430FR5722
8
1
8 1/1
10
17
24-VQFN
12 21 28-TSSOP
MSP430FR5721
4
0.5
8 2/1
12/2
16
32
40-VQFN
30 38-TSSOP
MSP430FR5720
4
0.5
8 1/1
6/2
10
17
24-VQFN
8/2
12 21 28-TSSOP
Functional Block Diagram For: MSP430FR5721IRHA, MSP430FR5725IRHA, MSP430FR5729IRHA, MSP430FR5731IRHA, MSP430FR5735IRHA, MSP430FR5739IRHA
Блок-схема микроконтроллеров MSP430FR57хx
Click to enlarge
ti.com
