Surface-mount thermogenerators supplant batteries
Micropelt TGP-651 TGP-751
Micropelt has launched compact thermogenerator package (TGP) devices that makes thermal energy harvesting ready for mass production. The devices enable automatic assembly of autonomous DC power supplies for ultra low power wireless sensors and actuators. Battery maintenance, a stumbling block in the deployment of wireless sensor networks, can be eliminated by TGP autonomous DC power modules whenever a temperature difference of 5 °C or more is available.
Micropelt: Surface-mount thermogenerators supplant batteries
Output power ranges from 100 microwatts to over 10 milliwatts, sufficient to replace most batteries. Micropelt's standardised TGP package comes in two interchangeable versions: TGP-651 and TGP-751. This allows output power and cost to be matched to target applications and markets without any changes to the PCB design.
The package concept is based on a rectangle metal-base laminate with a ring isolator, in order to achieve a good thermal performance by maximizing the thermal flow through the Micropelt thermogenerator chip. Together with a metal top, the components offer a solid and stable mechanical construction.
Microplet: устройство корпусного термогенератора для поверхностного монтажаMicroplet: устройство корпусного термогенератора для поверхностного монтажа
The TGP devices are designed for mounting in a sandwich configuration with a heat sink on one side and a PCB on the other side. The circular aluminium heat source interface passes through a 10 mm hole in the host PCB. The rectangular cold face carries the electrical contacts for reflow soldering and connects to the heat sink on its outer side. The device's vertical dimensions ensure sufficient clearance for electronic components mounted next to it below the heat sink.
Features:
  • Integrates Micropelt MPG-D751 or MPG-D651 solid-state thermogenerator
  • Maintenance-free solid state operation
  • Long life time
  • Compatible with automated placing & reflow production lines
  • TGP thickness offers adequate spacing for placing components on the PCB
  • Optimized mechanical design offers maximum thermal performance
  • Operating temperatures up to 140 °C
  • High output voltage per degree temperaturegradient (110 mV/K for TGP-751)
At relatively low thermal gradients (between 10 and 40 °C), both devices produce very similar power levels, so the TGP-651 with a 6 mm2 TEG is more cost-effective. The TGP-751, with a footprint of 12 mm², is preferable for situations with very low gradient or high power demand.
Generic power supply utilizing waste heat to drive Milliwatt (wireless) applications, including:
  • Wireless sensor networks (WSN)
  • Industrial process monitoring
  • Condition monitoring
  • Thermal event logging
  • Thermal triggering
  • Intelligent buildings and HVAC
  • Automatic meter reading (AMR)
  • Energy monitoring & control
micropelt.com
