Desktop milling machine creates PCBs and packaging
Other Machine Othermill
Version 2 of the desktop Othermill milling machine is now available, and it's accurate enough for a range of machining tasks, including double-sided PCBs.
Desktop milling machine creates PCBs and packaging Desktop milling machine creates PCBs and packaging
The machine can handle a range of materials, like brass, aluminum, wood, and plastic. For PCBs, FR-1 is recommended over FR-4. With a small milling bit, footprints as fine as TSSOP & TQFP can be created. Solder paste stencils can also be cut using the mill.
The Otherduino, an Arduino-compatible microcontroller.
Our free software, Otherplan, imports your designs in familiar formats — Vector graphics (.svg), Eagle (.brd), Gerber, and G-code. You can even download and cut millions of free vector graphic designs that are online.
Othermill software. A 4 × 4 wooden enclosure project.
 fast & precise
  • Precision: 0.001 in (0.0254 mm)
  • Max Traverse Speed (Rapid): 60 in/min (1,500 mm/min)
  • Spindle Speed: 7,000–16,500 rpm
Small & lightweight
  • Build Area: 5.5 × 4.5 × 1.25 in
  • Small Frame: 10 × 10 × 12 in
  • Lightweight: 16.8 lbs (7.62 kg)
The Othermill sells for $2,199.
EDN
