El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
The Texas Instruments OPA462 …
The Texas Instruments OPA462 op amp can provide ±90 V outputs while delivering to 30 mA typical
Bill Schweber
Learning to like high-voltage op-amp ICs
Figure 3
15 Kb
Figure 1. This basic circuit uses a pair of complementary discrete transistors to boost the output swing of a lower-voltage op amp
Figure 2. An improved voltage-boosting circuit requires significantly more components to ensure symmetrical and linear performance across the output's swing range
Figure 3. The Texas Instruments OPA462 op amp can provide ±90 V outputs while delivering to 30 mA typical
Figure 4. The ADHV4702-1 from Analog Devices is a 220-V device that can use symmetrical or asymmetrical bipolar supplies
