El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
Charge pump in applications …
Charge pump in applications with negative V
OUT
How to use a charge pump converter to meet your design needs
Figure 6
14 Kb
Figure 1. Voltage doubler diagram
Figure 2. Using a charge pump for an HS-FET
Figure 3. A charge pump in a boost circuit
Figure 4. Simplified charge pump in a boost circuit
Figure 5. Functional diagram for simplified charge pump
Figure 6. Charge pump in applications with negative V
OUT
OUT
