Auto-Audio
Bad Prescript
Music
This circuit senses the …
This circuit senses the solar panel's output voltage and adjusts the load to raise the voltage until maximum power is obtained
Abhijeet Deshpande
Maximum Power Point Tracker Optimizes Solar Fan Drive
Figure 2
16 Kb
Figure 1. The maximum power a solar panel can produce and the voltage at which that occurs varies with sunlight intensity, making the panels inefficient when handling static loads
Figure 2. This circuit senses the solar panel's output voltage and adjusts the load to raise the voltage until maximum power is obtained
Figure 3. A regulating pulse-width modulator chip that regulates the input voltage rather than the output voltage is the core of the maximum power tracker implementation
