Build a Solar Heater on the Cheap
Create a cheap and green solar heater for less than $10. All you need is foam board, lots of pennies, black spray paint, and plexiglass. The assembled product should be placed next to a window and can increase the room temperature by a minimum of 10 degrees (according to the video), depending on the amount of sunlight that reaches the heater.
lifehacker.com
