FET Supplies Low-Voltage Reverse-Polarity Protection
International Rectifier IRF7341 IRF7342
Jim Walker
Electronic Design
When a circuit requires reverse-voltage protection on the power input, the usual approach is a series diode (see the figure, a). But if the input voltage is low – say, two or three AA batteries – the 0.5-V loss of a Schottky diode may represent a significant loss in useful battery life. An FET can serve as a series diode with significantly less voltage drop (see the figure, b).
Figure 1. Typically, a series diode is employed for reverse-polarity protection (a).
Compared to a diode, a p-channel FET exhibits significantly less voltage drop (b).
If low-side switching will work, an n-channel FET can be used (c). Adding a resistor
and capacitor produces a “soft-start” function (d).
A dual IRF7342 FET was used (p-channel, with both sides wired in parallel) using a 3-V source, resulting in a voltage drop of only 100 mV into a 100-mA load. With a 4.5-V input, the loss is only 50 mV with a 100-mA load. If a low-side switch topology will work in the application, an n-channel FET can be employed (see the figure, c). A dual IRF7341 FET was used (n-channel, with both sides wired in parallel) with a 3-V source, resulting in a voltage drop of only 40 mV into a 100-mA load. A 4.5-V input results in a loss of only 25 mV with a 100-mA load.
If a "soft-start" feature is needed, it can be added with only one capacitor and one resistor (see the figure, d). The values indicated add about 100 ms of turn-on delay, as the FET goes from off through the linear mode to fully on.
Materials on the topic
electronicdesign.com
