This circuit is a simple ultraviolate light that can be powered by a 6 volt battery or power supply that is capable of supplying 1 or more amps.
Circuit diagram
Parts
C1 |
0.0047uf |
Mono Capacitor |
C2 |
0.1uf |
Disc Capacitor |
D1,D2 |
1N4007 |
Diode |
FTB |
Filtered Blacklight Tube |
IC1 |
555 |
Timer IC |
P1 |
10k |
Trim Pot |
Q1 |
TIP30 |
PNP Power Transistor |
R1 |
470 Ohm |
Resistor |
R2 |
270 Ohm |
Resistor |
T1 |
Medium Yellow Inverter Transformer |
MISC | IC Socket, Heat Sink For Q1, Screw, Nut, Wire and PC Board |
Notes:
P1 changes brightness of the black light tube.
