Datasheet STTH102 (STMicroelectronics) - 5
DescriptionHigh efficiency ultrafast diode
Pages / Page7 / 5 — STTH102. Package information. 2 Package. information. Table 5. SMA …
File Format / SizePDF / 105 Kb
STTH102. Package information. 2 Package. information. Table 5. SMA Dimensions. Dimensions. Ref. Millimeters. Inches. Min. Max. Figure 15
STTH102 Package information 2 Package information Table 5 SMA Dimensions Dimensions Ref Millimeters Inches Min Max Figure 15
● Epoxy meets UL94 V0
Table 5. SMA Dimensions Dimensions Ref. Millimeters Inches E1 Min. Max. Min. Max. D
A1 1.90 2.45 0.075 0.094 A2 0.05 0.20 0.002 0.008 b 1.25 1.65 0.049 0.065
E
c 0.15 0.40 0.006 0.016 D 2.25 2.90 0.089 0.114
A1
E 4.80 5.35 0.189 0.211
C A2 L b
E1 3.95 4.60 0.156 0.181 L 0.75 1.50 0.030 0.059
Figure 15. Footprint (dimensions in mm) 1.4 2.63 1.4 1.64 5.43 Table 6. DO-41 (Plastic) Package dimensions Dimensions Ref. Millimeters Inches ØD Min. Max. Min. Max. ØB
A 4.1 5.20 0.160 0.205 B 2 2.71 0.080 0.107
C A C
C 25.4 1 D 0.712 0.863 0.028 0.034 In order to meet environmental requirements, ST offers these devices in ECOPACK® packages. These packages have a lead-free second level interconnect. The category of second level interconnect is marked on the package and on the inner box label, in compliance with JEDEC Standard JESD97. The maximum ratings related to soldering conditions are also marked on the inner box label. ECOPACK is an ST trademark. ECOPACK specifications are available at: www.st.com. 5/7 Document Outline STTH102 High efficiency ultrafast diode Table 1. Absolute ratings (limiting values) 1 Characteristics Table 2. Thermal resistance Table 3. Static Electrical Characteristics Table 4. Dynamic electrical characteristics Figure 1. Average forward power dissipation versus average forward current (SMA) Figure 2. Average forward power dissipation versus average forward current (DO-41) Figure 3. Average forward current versus ambient temperature (d = 0.5) (SMA) Figure 4. Average forward current versus ambient temperature (d = 0.5) (DO-41) Figure 5. Relative variation of thermal impedance junction to ambient versus pulse duration (epoxy printed circuit board, e(Cu) = 35 µm, recommended pad layout) (SMA) Figure 6. Relative variation of thermal impedance junction to ambient versus pulse duration (DO-41) Figure 7. Forward voltage drop versus forward current Figure 8. Junction capacitance versus reverse voltage applied (typical values) Figure 9. Reverse recovery time versus dIF/dt (90% confidence) Figure 10. Peak recovery current versus dIF/dt (90% confidence) Figure 11. Reverse recovery charges versus dIF/dt (90% confidence) Figure 12. Relative variations of dynamic parameters versus junction temperature Figure 13. Thermal resistance junction to ambient versus copper surface under each lead (Epoxy printed circuit board FR4, copper thickness: 35 µm) (SMA) Figure 14. Thermal resistance versus lead length (DO-41) 2 Package information Table 5. SMA Dimensions Figure 15. Footprint (dimensions in mm) Table 6. DO-41 (Plastic) Package dimensions 3 Ordering information 4 Revision history
