AD8250* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017COMPARABLE PARTSREFERENCE MATERIALS View a parametric search of comparable parts. Technical Articles • Auto-Zero Amplifiers EVALUATION KITS • High-performance Adder Uses Instrumentation Amplifiers • AD8250 Evaluation Board DESIGN RESOURCESDOCUMENTATION • AD8250 Material Declaration Application Notes • PCN-PDN Information • AN-1401: Instrumentation Amplifier Common-Mode • Quality And Reliability Range: The Diamond Plot • Symbols and Footprints Data Sheet • AD8250: 10 MHz, 20 V/μs, G = 1, 2, 5, 10 iCMOS DISCUSSIONS Programmable Gain Instrumentation Amplifier Data Sheet View all AD8250 EngineerZone Discussions. Technical Books • A Designer's Guide to Instrumentation Amplifiers, 3rd SAMPLE AND BUY Edition, 2006 Visit the product page to see pricing options. TOOLS AND SIMULATIONSTECHNICAL SUPPORT • AD8250 SPICE Macro Model Submit a technical question or find your regional support number. DOCUMENT FEEDBACK Submit feedback for this data sheet. This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified. Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Diagram Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Gain Selection Transparent Gain Mode Latched Gain Mode Timing for Latched Gain Mode Power Supply Regulation and Bypassing Input Bias Current Return Path Input Protection Reference Terminal Common-Mode Input Voltage Range Layout Grounding Coupling Noise Common-Mode Rejection RF Interference Driving an ADC Applications Differential Output Setting Gains with a Microcontroller Data Acquisition Outline Dimensions Ordering Guide
