AD8417Data SheetTYPICAL PERFORMANCE CHARACTERISTICS1450401230V)1020E (µ G A8B)10dLT ON ( AIT V60EG–10OFFS4–202–300–40–40–25–105203550658095110125 003 100010k100k1M10M 006 TEMPERATURE (°C) 1882- 1 FREQUENCY (Hz) 1882- 1 Figure 3. Typical Offset Voltage Drift vs. Temperature Figure 6. Typical Small Signal Bandwidth (VOUT = 200 mV p-p) 1201091108100%)7R (B)90RRO6dERR (UT5P80CMUT4O L70A T3O T2601500101001k10k100k1M 004 0510152025303540 007 FREQUENCY (Hz) 1882- 1 DIFFERENTIAL INPUT VOLTAGE (mV) 1882- 1 Figure 4. Typical CMRR vs. Frequency Figure 7. Total Output Error vs. Differential Input Voltage 5000.5NORMALIZED AT 25°C4000.4300mA) 0.3IN (+IN)200P 0.2/V VUTµ1000.1NPR (R I0E0–INRROPN E –100NT –0.1AI G –200–0.2CURRE–300–0.3AS BI–400–0.4VS = 2.7V–500–0.5–40–25–105203550658095110125 005 –4 048 12 16 20 24 28 32 36 40 44 48 52 56 60 64 68 008 TEMPERATURE (°C) 1882- 1 VCM (V) 1882- 1 Figure 5. Typical Gain Error vs. Temperature Figure 8. Bias Current per Input Pin vs. Common-Mode Voltage (VCM) Rev. B | Page 6 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION OUTPUT OFFSET ADJUSTMENT UNIDIRECTIONAL OPERATION Ground Referenced Output Mode VS Referenced Output Mode BIDIRECTIONAL OPERATION EXTERNAL REFERENCED OUTPUT SPLITTING THE SUPPLY SPLITTING AN EXTERNAL REFERENCE APPLICATIONS INFORMATION MOTOR CONTROL 3-Phase Motor Control H-Bridge Motor Control SOLENOID CONTROL High-Side Current Sense with a Low-Side Switch High-Side Current Sense with a High-Side Switch High Rail Current Sensing OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
