Bidirectional, Zero-Drift, Current Sense Amplifier
Pages / Page
17 /10 — Data Sheet. AD8418. 0.4. –50. 0.3. –100. (m LI. 0.2. A –150. R E. 0.1. …
PDF / 331 Kb
Data Sheet. AD8418. 0.4. –50. 0.3. –100. (m LI. 0.2. A –150. R E. 0.1. –200. ITIV. OS –250. OM –300. MR C –0.1. FR –350. GE A. –0.2. LT –400. –0.3. –450. –500. –0.4
Data SheetAD841800.4–500.3V)–100(m LI0.2A –150R E0.1–200V)ITIVV/OS –250(µ0PROM –300MR C –0.1FR –350GE A–0.2LT –400VO–0.3–450–500–0.4012345678910 021 –40–25–105203550658095110125 023 OUTPUT SOURCE CURRENT (mA) 1546- 1546- 1 TEMPERATURE (°C) 1 Figure 21. Output Voltage Range from Positive Rail vs. Output Source Current Figure 24. CMRR vs. Temperature 2001800180)1601500mV140UND (1200120RO G M100ITS900HRO F80EAG60600LTVO40300200012345678910 022 –8–6–4–202468 125 OUTPUT SINK CURRENT (mA) 1546- 1 GAIN ERROR DRIFT (PPM/°C) 1546- 1 Figure 22. Output Voltage Range from Ground vs. Output Sink Current Figure 25. Gain Drift Distribution +125°CVS = 5V+25°C1800–40°C15001200ITS H9006003000–400–300–200–1000100200300400 024 VOS (µV) 1546- 1 Figure 23. Offset Voltage Distribution Rev. 0 | Page 9 of 16 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Output Offset Adjustment Unidirectional Operation Ground Referenced Output VS Referenced Output Bidirectional Operation External Referenced Output Splitting the Supply Splitting an External Reference Applications Information Motor Control 3-Phase Motor Control H-Bridge Motor Control Solenoid Control High-Side Current Sense with a Low-Side Switch High-Side Current Sense with a High-Side Switch High Rail Current Sensing Outline Dimensions Ordering Guide Automotive Products
