Datasheet AD8295 (Analog Devices) - 2
DescriptionPrecision Instrumentation Amplifier with Signal Processing Amplifiers
Pages / Page29 / 2 — AD8295* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 554 Kb
AD8295* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. DOCUMENTATION. Data Sheet
AD8295* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES DOCUMENTATION Data Sheet
View a parametric search of comparable parts. • AD8295 Material Declaration • PCN-PDN Information
DOCUMENTATION
• Quality And Reliability
Data Sheet
• Symbols and Footprints • AD8295: Precision Instrumentation Amplifierwith Signal Processing Amplifiers Data Sheet
DISCUSSIONS Technical Books
View all AD8295 EngineerZone Discussions. • A Designer's Guide to Instrumentation Amplifiers, 3rd Edition, 2006
SAMPLE AND BUY
Visit the product page to see pricing options.
REFERENCE DESIGNS
• CN0225
TECHNICAL SUPPORT
Submit a technical question or find your regional support
REFERENCE MATERIALS
number.
Technical Articles
• High-performance Adder Uses Instrumentation Amplifiers
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS INSTRUMENTATION AMPLIFIER SPECIFICATIONS, SINGLE-ENDED AND DIFFERENTIAL OUTPUT CONFIGURATIONS OP AMP SPECIFICATIONS INTERNAL RESISTOR NETWORK POWER AND TEMPERATURE SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS IN-AMP OP AMPS SYSTEM THEORY OF OPERATION UNCOMMITTED OP AMPS INSTRUMENTATION AMPLIFIER Gain Selection Common-Mode Input Voltage Range Reference Terminal LAYOUT Routing and Vias Common-Mode Rejection over Frequency Unused Op Amps Reference Power Supplies INPUT PROTECTION INPUT BIAS CURRENT RETURN PATH RF INTERFERENCE DIFFERENTIAL OUTPUT APPLICATIONS INFORMATION CREATING A REFERENCE VOLTAGE AT MIDSCALE HIGH ACCURACY G = −1 CONFIGURATION WITH LOW-PASS FILTER TWO-POLE SALLEN-KEY FILTER AC-COUPLED INSTRUMENTATION AMPLIFIER DRIVING DIFFERENTIAL ADCs OUTLINE DIMENSIONS ORDERING GUIDE
