Datasheet LTC3896 (Analog Devices) - 2
Description150V Low IQ, Synchronous Inverting DC/DC Controller
Pages / Page36 / 2 — absoluTe MaxiMuM raTings. pin conFiguraTion. All pins with respect to V. …
absoluTe MaxiMuM raTings. pin conFiguraTion. All pins with respect to V. OUT unless otherwise noted (Note 1). orDer inForMaTion
absoluTe MaxiMuM raTings pin conFiguraTion All pins with respect to V OUT unless otherwise noted (Note 1) orDer inForMaTion
LTC3896
absoluTe MaxiMuM raTings pin conFiguraTion All pins with respect to V OUT unless otherwise noted (Note 1).
Input Supply Voltage (V TOP VIEW IN) ... –0.3V to 150V Top Side Driver Voltage BOOST .. –0.3V to 150V OVLO 1 38 INTVCC Switch Voltage (SW) ... –5V to 150V VPRG 2 37 ILIM DRV SENSE+ 3 36 PHASMD CC, (BOOST – SW) Voltages .. –0.3V to 11V BG, TG ... (Note 8) SENSE– 4 GND Voltage .. –0.3V to 65V SS 5 34 RUN RUN Voltage... (GND–0.3V) to 150V V 6 FB ITH 7 32 EXTV (PLLIN – GND) Voltage .. –0.3V to 6V CC MODE 8 (PGOOD – GND) Voltage .. –0.3V to 6V V – 9 30 OUT VIN SENSE+, SENSE– Voltages ... –0.3V to 65V 39 V – 10 – OUT VOUT MODE, DRVUV Voltages .. –0.3V to 6V CLKOUT 11 28 NDRV ILIM, VPRG, FREQ, PHASMD Voltages .. –0.3V to 6V GND 12 DRVSET Voltage .. –0.3V to 6V PLLIN 13 26 DRVCC NDRV ... (Note 9) PGOOD 14 EXTV – CC Voltage ... –0.3V to 14V V 15 24 OUT BG ITH, V NC 16 FB Voltages .. –0.3V to 6V SS, OVLO Voltages ... –0.3V to 6V FREQ 17 22 BOOST Operating Junction Temperature Range (Notes 2, 3) DRVSET 18 21 SW LTC3896E, LTC3896I .. –40°C to 125°C DRVUV 19 20 TG LTC3896H ... –40°C to 150°C FE PACKAGE 38-LEAD PLASTIC TSSOP Storage Temperature Range ... –65°C to 150°C TJMAX = 150°C, θJA = 28°C/W EXPOSED PAD (PIN 39) IS V – OUT , MUST BE SOLDERED TO PCB FOR RATED ELECTRICAL AND THERMAL CHARACTERISTICS
orDer inForMaTion http://www.linear.com/product/LTC3896#orderinfo LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3896EFE#PBF LTC3896EFE#TRPBF LTC3896FE 38-Lead Plastic TSSOP –40°C to 125°C LTC3896IFE#PBF LTC3896IFE#TRPBF LTC3896FE 38-Lead Plastic TSSOP –40°C to 125°C LTC3896HFE#PBF LTC3896HFE#TRPBF LTC3896FE 38-Lead Plastic TSSOP –40°C to 150°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on nonstandard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 3896f 2 For more information www.linear.com/LTC3896 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Typical Application Related Parts
