Datasheet AMS1117 (Advanced Monolithic Systems)
ManufacturerAdvanced Monolithic Systems
Description1A Low Dropout Voltage Regulator
Pages / Page8 / 1 — Advanced. AMS1117. Monolithic 1A LOW DROPOUT VOLTAGE REGULATOR. Systems. …
File Format / SizePDF / 95 Kb
Advanced. AMS1117. Monolithic 1A LOW DROPOUT VOLTAGE REGULATOR. Systems. RoHs Compliant. FEATURES. APPLICATIONS
Datasheet AMS1117 Advanced Monolithic Systems
Advanced AMS1117 Monolithic 1A LOW DROPOUT VOLTAGE REGULATOR Systems RoHs Compliant FEATURES APPLICATIONS
Three Terminal Adjustable or Fixed Voltages*
High Efficiency Linear Regulators 1.5V, 1.8V, 2.5V, 2.85V, 3.3V and 5.0V
Post Regulators for Switching Supplies
Output Current of 1A
5V to 3.3V Linear Regulator
Operates Down to 1V Dropout
Battery Chargers
Line Regulation: 0.2% Max.
Active SCSI Terminators
Load Regulation: 0.4% Max.
Power Management for Notebook
SOT-223, TO-252 and SO-8 package available
Battery Powered Instrumentation GENERAL DESCRIPTION
The The AMS1117 series of adjustable and fixed voltage regulators are designed to provide up to1A output current and to operate down to 1V input-to-output differential. The dropout voltage of the device is guaranteed maximum 1.3V, decreasing at lower load currents. On-chip trimming adjusts the reference voltage to 1.5%. Current limit is set to minimize the stress under overload conditions on both the regulator and power source circuitry. The AMS1117 devices are pin compatible with other three-terminal SCSI regulators and are offered in the low profile surface mount SOT-223 package, in the 8L SOIC package and in the TO-252 (DPAK) plastic package.
ORDERING INFORMATION: PACKAGE TYPE OPERATING JUNCTION
TO-252 SOT-223 8L SOIC
TEMPERATURE RANGE
AMS1117CD AMS1117 AMS1117CS -40 to 125° C AMS1117CD-1.5 AMS1117-1.5 AMS1117CS-1.5 -40 to 125° C AMS1117CD-1.8 AMS1117-1.8 AMS1117CS-1.8 -40 to 125° C AMS1117CD-2.5 AMS1117-2.5 AMS1117CS-2.5 -40 to 125° C 8L SOIC Top View AMS1117CD-2.85 AMS1117-2.85 AMS1117CS-2.85 -40 to 125° C AMS1117CD-3.3 AMS1117-3.3 AMS1117CS-3.3 -40 to 125° C GND/ADJ 1 8 N/C AMS1117CD-5.0 AMS1117-5.0 AMS1117CS-5.0 -40 to 125° C V 2 7 V OUT OUT *For additional available fixed voltages contact factory. V 3 6 V OUT OUT V 4 5 N/C IN
PIN CONNECTIONS
SOT-223 Top View 3 PIN FIXED/ADJUSTABLE TO-252 FRONT VIEW VERSION 3 TAB IS OUTPUT 2 1- Ground/Adjust 1 1 2 3 2- V OUT 3- VIN
Advanced Monolithic Systems, Inc.
www.advanced-monolithic.com Phone (925) 443-0722 Fax (925) 443-0723
